BASS ON BOARD!
Ok there are a few threads of the issues my car is having with the return to idle and no engine braking. I’m at the stage where I want to drive it off a cliff.
Chiptorque had the car for 3 days and handed back to me with a big ![]() They have done multiple test and all passed. They want me to track down a Manual EL ECU to test in my car. So can anyone help me out? Some one also said to check all the earths in the rear of the car eg tail lights or fuel pump as all sensors share the same earth.
Nothing interesting to put here. |
The one and only
vegabass, I haven't been following this problem but what does rear earth have to do with engine braking?
How old is this motor? Have you checked your ICV?
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Two > One
The car is manual, and you have an Auto ECU in it that you were trying to chip?
BASS ON BOARD!
I should probably put the links in here...
It was a Auto, I did a manual conversion. It has a Chip with a custom tune incorporated with the Tickford manual settings. I laughed at the guy who told me about the earths for the tail lights but he said he saw a falcon that had issues with sensors, and the loom had been damaged in the boot from a minor accident. when they fixed the damaged wires all problems were gone. whats a ICV?
Last warning
idle control valve or idle speed controller (ISC)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Bring on the lion...
What about the throtle positioning sensor???
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD 9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile XC Falcon project car underway...... |
SnortPerformance.com
Throw it in the bin vegabass. Or if that sounds a bit rash just put a new motor and or wiring loom in it.
#8 | |||
BASS ON BOARD!
I have replaced
ISC TPS Intake temp sensor Power steer pressure switch Wired up neutral switch Oxy sensor ECU tested Loom test (apparently) Chip tested Don’t get me wrong the car still works... 14.7 1/4mile And this at the skid pan... (thanks penelope ![]() ![]()
BASS ON BOARD!
Bump !!!
Oops, I slipped....
Does it do it every time you rev the motor?
Is the butterfly closing when you back off? I noticed on my car when I adjusted the TPS's, if I overtightened the screws the throttle was stiffer, and wouldn't snap close as easy. Broken throttle return spring maybe?
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#12 | ||
Two > One
get
a manual ECU
Oops, I slipped....
Oh, I thought that bit was pretty straightforward, like asking "Do I need a clutch with a manual"...
#14 | |||
BASS ON BOARD!
Chiptorque have played with that and no such luck. Im going to take it to a friend in auto electrics to see if he has any ideas Yes it happens when the engine has warmed up. when its cold it will behave. walkinshaw.....know where I can get one?
#15 | ||
Two > One
There is a place in QLD where you can buy new/remanufactured ECU's of any catch code. Somone may be able to remember the name of the place.
#16 | ||
BASS ON BOARD!
Chiptorque know who it is so ill give them a buzz.
Anyone want to make a offer on it? Im 2mins away from putting it up for sale!
#17 | |||
nah just keep persisting with it. you will figure it out in the end....anyone want to buy my car??LOL |
#18 | ||
il take it john!
be an awsome wreaker:P p.s does this include the 3.9 bwhahaha! |
#19 | ||
SS Grunt
checked compression? could be low and would explain no engine braking.
#20 | ||
BASS ON BOARD!
Ill be checking the compression tomorrow!!!!
However, I unpluged he ISC and started the car, drove down the street and what would you know..ENGINE BRAKING AND QUICK REVS!!!! so I adjusted the idle screw to make it idle and left the ISC unpluged! ISC......who needs em.
