04-01-2019, 01:15 AM | #1 | ||
Hi Guys,
Currently working though an issue with the radiator fan on the car mentioned above. Firstly, we noticed the car overheating ONLY when sitting idle for around 5 or so min with the AC on, then the AC getting warm Had a look today and noticed the Radiator Fan not spinning at all on a 33 degree Canberra summer. Got a multimeter to the plug and no power. Checked Engine Bay fuse box and the 40A Cartridge Fuse was blown. Replaced it with another 40A Fuse. Took the car for a drive 'Great the AC is working properly' however upon letting it idle at home, my partner could smell something burning. Checked the Engine Bay, and behold the smell was there, mainly towards the fuse box side of things. Turned the car off and check the cabling underneath and the cabling was well hot to the touch, alot more than expected. Unplugged the fan and let the car sit for 30 or so minutes to get rid of the smell. Fired the car up and no smells where observant. Now apart from the above, what would you say the issue relates to? Replacing the Radiator Fan? Stuffed Cabling/Plug? Any help would be appreciated. |
04-01-2019, 09:32 AM | #2 | ||
Chairman & Administrator
You only need to ask once, not three times.
It sounds like a short in the wiring somewhere in the fan loom which would explain the blown fuse and the hot wiring. Apparently the Ford diagnostic system can test the fan so maybe that's worth a try to at least rule it out.
Observatio Facta Rotae
04-01-2019, 12:12 PM | #3 | ||
Hi Andrew,
I'm having the same problem right at the moment with my 2009 Fiesta Econetic. With mine I discovered the fan was jamming, it would spin for around 3/4 of a rotation then get stuck. Seems to be an internal problem with the motor. From the internet research I can find it appears these cooling fans are poorly made with the brushes wearing down and eventually failing. My Econetic has 173000km on the clock, I think once you get some high Km it's almost a given that these fans will fail. https://www.youtube.com/watch?v=5FFMhptloDI I found a youtube video that shows the problem: "Ford Fiesta 2009 Onwards MK7 Cooling Fan & Aircon Issue, Diagnostic and tear down" Is there a knack to disconnecting the electrical connector off the fan? Mine is stuck and I can't get it off. Bill |
06-01-2019, 01:50 AM | #4 | ||
I have same problem (except no blown fuse). It's a new fan unit we need. Haynes book and YouTube have good guides on how to replace.
Self servicing my Ford Fiesta WS 2010 Petrol to learn more about cars |
