Lost Boost Gained Class
ok guys i need help im outa ideas....
this is what happend i drove the car one day all good i put $20 worth of Ron 98 next day started it and it sounded like its on 5 cyl of changed spark plug leads Spark plugs iv checked for spark on all cyl .... Going to change coilpack with spear 100% knowing that it works im outa ideas :( could bad batch of petch do this or is there something i could check for like stuffed rocker or something....
2006 BF Fairmont Ghia
2001 AU Falcon |
meh.
![]() Join Date: Jul 2010
Injectors or Coil Pack would be my guess....
i dont think its injecters its to of a sudden thing... im just seeing what other things it could be / look at i gota fix this as i need it... and my BA is going for a tune
2001 AU Falcon |
Walking with God
Bad batch of fuel?
Hope you get it sorted soon. GK
Bugger!
Where did the fuel come from?
Could be the fuel filter/pump? Bang the tank while the car's running, see if the noise from the pump changes... Vacuum leak? How clean's the front of the motor, the crank angle sensor could be fouled? Does it rev cleanly? Fuel smoke? Lifters will make a ticking/rattling sound if stuffed.
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 ![]() |
i got the petch from my normal place 7/11 old Mobal servo (good turn over)
No vacume leaks the bay gets cleaned every cupple of weeks to watch for leats and so on pump in tank i donno iits a bit hard to know as the car is Loud lol there was a ticking sound comeing from the car when it gets hot b4 this happend ill have to try and see i might go to another servo and get some more fuel and see if it helps or not the car isent reving well down low once it gets up speed it feels ok ish not right but better
2001 AU Falcon |
Bugger!
Sounds like bad fuel or weak spark......
Low fuel pressure is normally worse under acceleration. Does it have reasonable power? Could be a blocked cat but that's not usually a sudden thing.
its got power its worked lol....
na it feels like its not running on all cyl i might put a few leters of clean fuel in her and change the coil pack and see what happens what do u guys think
2001 AU Falcon |
Bugger!
Sounds like a good starting point, yeah. Don't think from what you're saying that it'll be anything very major
yeah ill give that a try if all fails ill post back my findings with a vid if i need to
2001 AU Falcon |
rexnet
coil pack wet? i find if my coil gets wet it runs like a pig. any of your plugs/leads died?
#12 | ||
you beat me too it Day-mow , was just going to say , have you washed the engine recently? been through any floods lately?
Disconnect the injector electrical connector for each cylinder one at a time.
If it makes no difference to how it runs then that cylinder is where your problem is. It won't tell you WHAT is wrong but it has to be either fuel or spark. |
#14 | ||
Ba the bay hasn't had a wash in weeks I put new spark plugs and leads on it yesterday soo I'll give all that a try Sunday when I'm home next
2001 AU Falcon |
#15 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Uk
#16 | ||
Cracked spark plug ? Does it do it at idle ? If so remove 1 lead at a time until you find which cylinder .
Could be Coil pack though if its constant . Ticking when hot , IS it low on Oil ? maybe the oil is in need of a chnge
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . Last edited by dieseltrain79; 11-11-2011 at 10:18 PM. Reason: edited words |
#17 | ||
na old leads where stuffed so thay got the bin (thay broke when removeing)
na its not low on oil it has just devalaped a tick when its hot i donno yet .... this is how it sounded when working right http://youtu.be/FN_tJfHdHR8 and http://youtu.be/bDQN8T1Px90 and http://youtu.be/o_znZjgh6aE
2001 AU Falcon |
#18 | ||
ok guys i pulled the injecters off and found number 6 did not make any dif so i investergated more and found number 6 on the coil was giveing odd a lazy spark when it felt like it or not at all ....
Changed the coil pack and the thing fired 1st kick thanks for the help guys
2001 AU Falcon |
#19 | ||
Can you try to describe what "sounding like its running on 5 cylinders" sounds like? I noticed today that my AUIII I6 engine note seems to be more rumbly and throaty, actually sounds pretty cool, but I know it's not normal. :(
I've only ever had random split second misfires due to bad leads, never a cylinder that is totally dead, so I'm not sure what it sounds like... guess I'll be trying the sparks and/or injector plugs tomorrow to see what happens. |
#20 | ||
ill upload a vid my au dose not sound like a nromal au
2001 AU Falcon |
#21 | ||
2001 AU Falcon |
#22 | ||
Cheers for that. Hmm, mine is sort of like that, it is chugging a little, but not quite so bad. Once I'm in the car and driving I don't notice any difference, apart from the trip meter showing excessive consumption (got past 17L/100km the other day)
In the past 6 months I've replaced leads, sparks, coil pack, O2 sensor... so I'm thinking by now it's probably something mechanical. :( Or maybe an injector... When pulling the injector connectors do you stop the engine between each one, or can you do it on the fly? |
#23 | ||
do it on the fly leave it running
2001 AU Falcon |
#24 | ||
Ok, next silly question. How are you supposed to disconnect the individual injectors? It's impossible to pull them all at the injector itself for most of them (fuel rail, air tubing etc in the way) so is there a way to disconnect them individually at the other end of the cable, or do they all feed into a single connector?
Found another coolant leak. *sigh* |
