Old 16-08-2011, 07:42 AM   #1
Ekka 66
Unhappy Mondeo dramas
Hi guys and gals I have a ford Mondeo 97 2.0 lt auto Ztec engine with a few dramas first the gearbox wont change up as if the modulater valve is not working(if it has one) and the governer makes it change up.
Also need a timing belt marks diagram
And the radio keeps coming up error and wont let me put code in
Any help greatly appreciated Thanks
Ekka 66 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2011, 07:20 PM   #2
Mackspower
Default Re: Mondeo dramas
Definitely check the DC power connection to your radio . . . look for anything that would make the connection intermittent (connector/s not plugged-in properly, loose fuses, etc). Sounds like power is being applied and lost many times.
Can't verify the source accuracy of this doc so please check: Page 2 has the timing markers;
[CODE]http://www.fileserve.com/file/Q4YwNNG/Mondeo_timing_belt.pdf
[/CODE]
Can't help at all with the auto . . .
Good luck,
Mackspower is offline   Reply With Quote Multi-Quote with this Post
