Old 18-04-2009, 05:22 PM   #1
4dlvr
4dlvr
Default changing head lights
06 fiesta
when changing head lights do i need to undo the screws behind the light???
or do i just pull out the rubber protector behind it and go from there???
cheers
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2009, 05:37 PM   #2
Zetec Dave
Originally Posted by 4dlvr
06 fiesta
cheers
I would imagine its a simple matter of pulling out the rubber moisture seal and then unhook the wire holding the bulb and hey presto. Unless you've got one of those small (H1's I think?) that has a wire connected to it then you might have to unscrew something.
Zetec Dave is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2009, 09:32 PM   #3
Ben85
Ben85's Avatar
Just have to move the coolant overflow so you can get to it. Remove the rubber and unhook the wire, the wire can be a bastard to undo and do back up. But thats about all you have to do.
2006 WQ Fiesta Zetec Sea Grey
Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp.
Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction.
Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's.
Ben85 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 12:42 AM   #4
4dlvr
4dlvr
thanx ben.. reason why i asked was iv herd of people screwing up there light direction and auto director thingi
96 EF FAIRMONT
215rwkw @7psi
Old 19-04-2009, 10:11 AM   #5
Ben85
Ben85's Avatar
Your welcome mate. I have changed the bulbs in my car heaps of times, and have never screwed it up.
