Old 13-05-2007, 10:16 PM   #1
Keith61
Default were does the jack go
Hi all
I have just got a 2000 AUII XL traytop , But there is no book with it I would like to know
1/ were does the jack go as it is in a box on the tray were it will get stolen if I leave it there but i cant see any were else for it to go.
2/ I have 2 remote door fobs one didn't work it had a broken pin to the battery I fixed that and is now working the other one flashes but wont unlock the doors is there a way to reset so it will work
thanks Keith
Keith61 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 10:21 PM   #2
FGII-XR6
FGII-XR6's Avatar
if i remember correctly it is stored behind the seat
Old 13-05-2007, 10:28 PM   #3
Keith61
Default I looked there
I looked there , there was nothing to hold it in place it would just slide around and the boxed shelf doesnt open as far as i can tell
thanks keith
Old 14-05-2007, 06:23 AM   #4
au2sw
Blown 5L coming
au2sw's Avatar
not being a ute owner, im not sure about the jack, i think it just sits on the floor under a seat if you want it in the cab. as for the fobs, simply turn ignition to accessories, press the dimister button 3 times in 5 seconds. doors will cycle to indicate the vehicle is in learn mode. press the unlock button on each of the keypads (all keypads need to be re-set once the vehicle is in learn mode) turn the ignition to off. doors will cycle to indicate that the key pads are trained.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 08:39 AM   #5
Mechan1k
Mechan1k's Avatar
Mine was in a carpetted bag on the back shelf ... along with the attachaments and the bar that lowers the spare tyre as well.
Mine didn't move around though as it was that heavy.
I have mine on the floor under the passenger seat kind of .... mainly because I have my subs and amp taking up the entire rear shelf ... and an amp under the driver's seat as well.
I really don't know how i fit all of the crap I do inside the cabn of my ute though.
Old 14-05-2007, 11:50 AM   #6
Keith61
Default Thankyou for the help
The fob now works
As for the jack Iam going to make a sliding tool box to go in along side the number plate under the tray
thanks for the help
Keith
Old 14-05-2007, 05:13 PM   #7
T3man
T3man's Avatar
The jack usually resides in a bag under the seat or behind the seat area. To be honest you can leave it in the tray where everyone can see it without any worries 'bout it being stolen because every man and his dogs knows it is a worthless POS. Be wery wery carefull if you ever have to use it. There have been many documented cases of them collapsing whilst in use. Yet FoMoCo still refuse to admit a fault and do a recall - I guess when some poor b@rst@rd dies under a car the authorities will force Ford to address the problem.
Old 14-05-2007, 08:59 PM   #8
au2sw
Blown 5L coming
au2sw's Avatar
^^^^^yes, but unfortunatly, they will turn around and say it wasnt the jacks fault, the ground must have been too soft, the jack was improperly positioned...etcetc anything but admit fault and waste money on doing a recall
