Old 10-05-2007, 03:21 PM   #1
ravnuz
Default Brake Lights Not Working...*sigh*
Hi Guys,
The break lights on my gfs 1999 AU Forte dont work ... We bought it 2 nights ago, so I dont know if theres something wrong with the wiring or not? Ive checked all the obvious things ie Fuses, Globes and etc ... the park lamps work fine ... just tht when you press the brakes Nothing happens ... the cars got 2 extra brake lights as well ie one on the spoiler and one on the parcel shelf but none of em work : So it has to be the wiring yea?
I waz hoping you guys could point me in the right direction
Thanks,
Oz
ravnuz is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2007, 03:39 PM   #2
Mechan1k
Mechan1k's Avatar
Brake light switch under the brake pedal. Common issue with the Falcons.
Not too badly priced from Ford either.
Old 10-05-2007, 03:43 PM   #3
ravnuz
Thanks Mechan1k ... I went under there before but cudnt really see anything ... but ill replace it and hope it works
Cheers!
Old 10-05-2007, 05:03 PM   #4
Cobra
Bear with a sore head
Cobra's Avatar
You can easily check if the brake light switch is fauly by removing the it from the pedal and probing the connecor using a paper clip. If you bend the paper clip around so it's connected into both terminals of the connector it will complete the circuit. If your brake lights work by doing this then your switch is at fault. If it still doesn't work then you have a problem elsewhere.
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2007, 05:23 PM   #5
DOHC-DJ
DOHC-DJ's Avatar
yer thats exactly what i was going to say. just bridge the switch out and see if your brake lights work. if they do go to ford and get a new one. i think there only about 40 bucks max retail. dont buy the cheap aftermarket ones as they tend to fail again in a few months. (from experience)
DOHC-DJ is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 07:26 PM   #6
ravnuz
hey dudes,
Ummmm this is gonna sound really noobish :P but where exactly is the brake light switch? is it the thing on the shaft tht leads to the brake pedal?
Thanks in advance,
Oz
Old 24-05-2007, 05:52 PM   #7
ravnuz
Changed the brake switch but still no stop lamps :( ... everything else seems to be in order and all fuses are ok ... any suggestions?
Old 24-05-2007, 06:09 PM   #8
whiskers
gone fishing
whiskers's Avatar
have a look to see if the stop light in the back window lights up, if that lights up then defiantly check the globes or just give the side 1/4 panels a hard tap , as the wires might not be connecting properly.
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2007, 08:42 AM   #9
janek
Ripping it up
it will be as mechanik said- the brake light switch, pll put monry on it. cheap to replace too
janek is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2007, 11:30 AM   #10
JC
JC's Avatar
Change your globes. A visual check doesn't always show that a globe's blown or not. If it still doesn't work, take it to an auto ecletrician - they will diagnose it quickly for you.
Ford Performance Club ACT
