MADED.6
well i went to calder park on friday night and my best time was 15.41 at 92.28mph (i thought it was a little higher but i was wrong) i was hoping my car could run mid-low 14's
now i think it still could because on that run my times were 60ft - 2.446 660ft - 9.995 at 73.12mph ET - 15.410 at 92.28mph no on that run i got a fair bit of spin in 1st and 2nd gear and i am not a very fast shifter and never flat shift or anything. i got told to flat shift 3rd to 4th and go really hard from 2nd to 3rd i dont do this beacuse i dont think i am quick enough. i thought i was going to get a 14 but missed third because i got 1 2.2 60ft time but as i said i missed third in a bad way and thought i stuffed my gearbox. now i am going to the aff drag day next month at heathcote and would like to get some good times there. my car consist of a fully rebuilt bottom end with slightly higher comp acl race pistons (9.2:1) and then headwork done by swanny (trick_xd) and a dev5 cam and just paccie 4499's and 2.5inch exhaust. it is manual with a b&m short shifter and it has 3.7 diff gears. i was running 205/65r15's on the night at 27psi then i tried 20psi and still couldnt get grip. now as i said my 60ft times are getting better but still need alot of work as i am getting spin should i let th clutch out slower or wat. i am frustrated as i just spent $4,000 rebuilding the motor and it feels alot better than it used to and gives alot of cars a run for there money. i can beat my brother in his au3 xr8 by a little bit and i smoke ba's and the sort. sorry for having such a long thread hopefully someone can help me out. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
G,day mate. I,m only typing this on the pretence you will trust what i say!!! Being an auto BA i dont suffer the problems you are facing, but i did when i had a Vortech blown EB XR8-5 Speed . OK when in prestage pull handbrake on/load up clutch no more than 1000 rpm!/now you can focus on lights NOT tacho because of handbrake, you will obviously be in first gear so hand on brake/wheel /FOCUS...Second last amber FOOT to floor release clutch and handbrake at same time , around 30psi if street tyres, 12psi if a smallish slick Good luck keep me posted...
#3 | |||
low wagooon
This is rollins guide to gettin off the start
Webby
S2 AU XR6 UTE |
Formally ED I6
Lack of traction is your problem. 205's are way to thin to get a good 60' in my opinion.
What clutch are you running?? Does the clutch slip at all??
Daily driver 98' AU 349ci Fairmont Ghia on LPG --------------------------- Other 93' ED 5spd 4.0L NA Fairmont 13.75 @ 101mph |
MADED.6
the clutch is a exedy cushion button clutch and nah doesnt slip at all maybe a bit to bitey as u cant really feed it in wen foot flat coz it grabs to quick. but i am pretty happy with the clutch. also for anyone that came to clader did u notice my car single spinning coz i just got the lsd redone and want to no coz it is under warranty for 12months.
i will keep trying and i am hoping for mid 14's next time i get out there. cheers josh.
EBII XR6
Sorry to hijack here but can someone explain what flat shifting is please?! Any other terms would be great too.
I dont know much at all about drag racing but I am hoping to make it to heathcote next month to get a starting ET so I know where my car is at now. That way in the future I'll have something to compare to.
DEVLXR
MADED.6
flat shifting is wen u dont let go of the accelarator so it revs up and u gotta be quick.
cheers josh.
TL40 Wagon?
You are smoking it up too much off the line work on a clean launch the 2.4 60' is whats slowing the time down. The TS is good so you have decent power just work on being calm not trying tooo hard and being smooth off the line not brutal
i still managed a 14.6 in my old ED even with my crap 60 ft time. this was at heathcote tho.
mods were dev3hl/genie extractors/3.45diff/T5 manual/headlight out. i ran a 14.6 again at calder with same mods except for a 3.9 diff and a dev5 cam. dont know my 60 ft time tho. John_LS1 ED Fairmont Ghia N/A 60ft 2.300 660ft 9.460@76.25 1/4 14.607@96.96 something is definetly up with yours. does it feel like it has flat spots of power? |
the tyres arent helping. you need some 235's. You need to be able to slip your clutch a little. (even though its not the best for it).
I launch at 4000rpm, with NO wheelspin problems. 1.9 second 60fts. I have also missed 3rd, but still ran a 14.4... ![]()
Powered by Rollin Motorsport Turbo Barra ED 4L
MADED.6
nah doesnt feel like it has flat spots feels really good actually. and i didnt just miss third i grinded it and took probly 1-1.5 seconds to get it in. i thought i wrecked my gearbox because it wouldnt select at all had to clutch out then back in again then it went on so yeah. and also grechie was getting same times as me which he was getting 14.4 last time out and he had same problems everyone on street tyres had traction probs on the night.
ill see how i go next time. cheers josh.
#12 | ||
everyone puts shitty tyres on the back to go racing but you should use the best you have, the shiny smooth track hardly takes any rubber off at all so dont be afraid. i would say 235s minimum an if you have 8 inch wide 17's use them. i left my 17s on in a standard ef with a catback manual and xr diff (and a pair of subs on the boot) and i ran 15.44 with a totally rooted gearbox. so use your best tyres let the pressure down to about 15-19 for 17s dependin on what the track can handle. like many people have said basically dump it with a little bit of slipping an go hard. i dont find flatshifting helps just burns a bit more clutch, but dont let the accel. off all the way.
(you could always try the first timers trick an go buy 3 bottles of octane booster) oh and ps you are better putting the 205/65 15s on the front and pumpin them up to 40-50 psi less rolling resistance than 17's Last edited by EF_Frmnt; 16-04-2007 at 10:29 PM. Reason: more info :) |
I build your wish list...
Hey Josh
Your car was quick .. you Nealy got me at the lights remember. Traction was bad .. I spun at the lights and at about the 60foot mark .. then spun 2nd and chirped 3rd. How was yours going .. I noticed that my car is slower at top end .. I crossed the line in 3rd gear @ 5,600rpm 95MPH .. my 60Foot is a 2.170 and 2.159 I just think it was not our night for quick runs.. Oh - Well Next time... At least you have a time to beat now
If it weren’t for physics and the law enforcement, I’d be unstoppable.
#14 | ||
![]() Join Date: Jan 2005
Your tyres are the problem for sure, I didn't have any traction problems on that night (had 235's) Try using better tyres, should hopefully get you into the 14's with a decent 60'. I could launch mine from around 4K RPM+ and get a good launch and i'm using a similar clutch to yours.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#15 | ||
BTW that quote from Rollin is SPOT ON, follow that and you'll have good launches.
