Old 10-04-2007, 06:06 PM   #1
Burley
CRE.87V
Default AU XR6 vct probs
hey all....getting a slight tapping noise coming near inlet manifold at idle and even driving along....just changed inlet man gasket....just changed oil pressure sensor/switch....it still is showing low oil pressure on dash got it checked and is fine..got told it may be the oil pump not pumping? *** could this prob be.. i used genuine ford oil and filter...wat oil should i be using..car has done 105000kms
just changed thermastat plus gasket plus housing gasket where the leak was....after a month after changing there is a slight leak of coolant on the housing....
cheers
burley
Burley is offline   Reply With Quote Multi-Quote with this Post
