Old 10-04-2007, 08:55 AM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Good vibrations
Think I may have broken something real good in the ute...
I get a bad vibration which I can almost pinpoint to the tailshaft joining with the transmission, that's where I feel it's vibrating the worst. I was thinking uni joint but if that was the case, I wouldn't be able to drive it.
Can anyone point me in the right direction?
Carless
Old 10-04-2007, 08:39 PM   #2
bodes-sh
need a bit more info than that....ie does it only do it at a certain road speed, engine rpm, gear, or what?
Old 10-04-2007, 10:57 PM   #3
Bundy
All Ford Club Life Member
Bundy's Avatar
what were you doing at the time of the vibrations starting?? Or is that best left unsaid!!
Worked AU XR8 Ute - Toy
Std FG XR6T Ute - Daily
Supercharged BA 6 Ute - Wife's daily
351W F150 93 XLT 4x4 Supercab
Bundy is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 11:02 PM   #4
blackers10
blackers10's Avatar
i believe he told me he was practice launching at maloolaba for friday night before the noise started and so pulled out of running the uterus due to said noise...
Old 11-04-2007, 08:56 AM   #5
TheSneakiness
Adapt or perish...
Anyway, it occurs in first gear, 50%+ throttle, will do it from 2500rpm onwards intermittantly (ie: it'll do it, then stop, then do it again). The rubbing sound I'm hearing is hard to explain without either anyone else being in it, or without a sound file.
Carless
Old 11-04-2007, 03:01 PM   #6
TheSneakiness
Adapt or perish...
Went up the road before, I think before doing anything drastic, I'll get all my wheels rebalanced and aligned, see what that does. I think my rear tyres have had it too, to what effect that has on this vibration will remain to be seen.
Carless
Old 12-04-2007, 04:46 PM   #7
blacklabel
blacklabel's Avatar
Could be a number of things,such as bent propellor shaft,or drive shaft out of balance.
But DEFINETLY get your rear wheels balanced and checked,as you said you were going to.
I had a similar vibration once that was getting worse by the day.I could have sworn it was drive-train/gearbox related because of the "feel" of the vibrations.
Man-was I wrong. The problem was my rear wheels were out of balance and the vibrations were going through the whole subframe and because I could feel them through my seat, I thought it was drivetrain.
So get those rears checked and balanced before going any further is my advice.
Good luck! :voldar02:
blacklabel is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2007, 04:49 PM   #8
The Monty
Just slidin'
The Monty's Avatar
I had some reeaalllyy bad vibrations in my old Camry once. Turned out the steel belt on the tyre had peeled right up on one side, on the inside, and on the other side, the tyre had grown three massive orange sized lumps. I got new tyres the next day, and it seemed to fix them.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 12-04-2007, 07:39 PM   #9
samftr
samftr's Avatar
OH kenny, Jump under the car ;) and have a wiggle of the tailshaft where it joins into the extention housing... My ea's extention housing and the EB my cousin had did wear out. they make some bad vibes and some funny noises too...
could be that tho..
lemme know I have one here ;)
Simbooo
FG
Felcen!
samftr is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 09:09 AM   #10
TheSneakiness
Adapt or perish...
I've got the ute at Pedders at the moment getting rear suspension bushes replaced to finally eliminate some squeaking, and if it's helped some of the vibration that'll be another step closer to pinpointing it.
Sam, I'll have a look over the weekend and I'll let you know.
Carless
Old 13-04-2007, 10:05 AM   #11
blackers10
blackers10's Avatar
u shoulda asked em to have a look see if they could see a problem while they were under it ..
Old 13-04-2007, 04:12 PM   #12
The Monty
Just slidin'
The Monty's Avatar
Also Kenny, when I punched the top out of my shockie in the rear, it made great vibrations as there was no oil in it. Maybe this could be the problem?
Old 13-04-2007, 04:24 PM   #13
MYEBII
MYEB
tailshaft needs balancing???? or is that ba only??
MYEBII is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 04:39 PM   #14
TheSneakiness
Adapt or perish...
Car is back from Pedders.
No squeaks when I stop or go now. Also, that vibration is goooone.
I figure one of the bushes was shot to pieces and something was sitting loose in the rear end. It's so much better now.
Carless
Old 13-04-2007, 04:43 PM   #15
The Monty
Just slidin'
The Monty's Avatar
Good to know Kenny. Glad its all sorted.
Old 13-04-2007, 05:47 PM   #16
TheSneakiness
Adapt or perish...
Yeah, it's good that it's all better.
I just need new rear tyres now...
Carless
Old 13-04-2007, 10:49 PM   #17
blackers10
blackers10's Avatar
2 many test launches in the back streets on the way home from pedders kenny??
glad it wasnt anything "serious" and $$
Old 14-04-2007, 09:27 AM   #18
Mechan1k
Mechan1k's Avatar
Good to hear it was only the bushes then.
