Old 05-04-2007, 06:27 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default XR or Fairmont dash
I'm thinking of fitting a full instrument Fairmont/Fairlane or XR dash to my wagon but as it has the Tickford LPG dual fuel setup I'm not sure. Would one of these dashes work with a Tickford dual fuel setup where the gas tank is hooked to the fuel gauge and shows DTE for the LPG as well as the petrol and will I need to change anything to get the oil and amp guages working?
Has anyone done this switch before?
Bushbasher
MINE- AUII Forte
Old 06-04-2007, 11:57 AM   #2
StealthAu
for starters the fairmont/lane cluster dosn't show a dte as its on the trip computer.
Old 06-04-2007, 12:16 PM   #3
GK
Walking with God
GK's Avatar
Good point. Go the XR dash then, but much more expensive!
I've just decided not to do it on mine. I've always wanted to, but the cost is too prohibitive for the one extra functional gauge.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 06-04-2007, 12:23 PM   #4
StealthAu
whats the extra function?
Old 06-04-2007, 12:32 PM   #5
b2tf
not here much anymore
b2tf's Avatar
low series has speedo, tacho fuel and battery gauge IIRC?
XR/Fairmont has speedo, tacho, fuel, battery and oil pressure.
As has been said, Fairmont shows DTE in the MDC which is a seperate part of the dash (have to have a full Fairmont dash to fit it). XR shows DTE in the LCD of the cluster.
2024 F150 XLT
Old 06-04-2007, 12:43 PM   #6
JC
JC's Avatar
Close - Low series has Tacho, Speedo, Fuel & Temp
XR has oil pressure, volts, Tacho, Speedo, Fuel & Temp
So really, the volts is the only additional extra function that is worthwhile, and you can pick up an electronic oil pressure gauge with sending for around the $100 mark. A much cheaper option than an XR cluster at around $150, plus around the same again to get VDO to set the KMs from your old cluster, plus the $50 or so for the pressure sender, and another $20 for a long 27mm socket to install the send unit.
Ford Performance Club ACT
Old 06-04-2007, 07:40 PM   #7
S3SR
S3SR's Avatar
but the xr/fairmont cluster looks 1000000x better than some gauge sticking out of the dash
my forte/low series dash has the DTE on it or are we talking about something else
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 07:47 PM   #8
StealthAu
nope, yours has it as do all au's. But the fairlanes and fairmonts arn't in the cluster, they're shown on the trip computer
Old 06-04-2007, 08:54 PM   #9
JC
JC's Avatar
That would be in your opinion.
Old 06-04-2007, 09:19 PM   #10
Bushbasher
Bushbasher's Avatar
Ok, so let me see if I've got this straight, The Fairmont dash is out with no DTE so it's XR dash or nothing and I'll need to change the oil pressure sender if I fit the XR dash. Cool, that's not too much drama but I still don't know if the fuel gauge and DTE will work with the LPG system....anyone????
And I agree, the full instrument dash looks alot better than some extraneous gauge hanging out of the dash somewhere. The 2 extra gauges do make a difference to me as well, especially the volts because I run an Engel in the back straight off the battery and also the spotties when travelling so I like to keep an eye on the power level and what the alternator is doing plus I just like the look of a full instrument dash over the base one. As for resetting the odometer, I probably wouldn't bother, especially if it's one with around the same ks' as mine.
Bushbasher
MINE- AUII Forte
Old 07-04-2007, 02:31 PM   #11
HLC
Audi S3
fairmont dash is out unless you want to fit the WHOLE dash.
on the 'monts, DTE is separate from the cluster etc.
XR dash's are physically the same as yours. just the cluster is different. so yeah. xr = easier.
Old 07-04-2007, 06:20 PM   #12
StealthAu
Fuel gauge and DTE will still work as it is now if changed to an xr dash.
Old 08-04-2007, 04:58 PM   #13
chief
FTF Club Moderator
chief's Avatar
I will be putting a black Fairmont dash in my Forte some time in the near future. I already have the new dash sitting on my bedroom floor. Stav can testify to that lol. Also the air con on a XR dash in cable controlled and a Fairmont dash has a little solinoid to control the air con, as its operated via the MDC.
The buttons on the dash will need to be rewired to fit the loom of the MDC. There is some stuffing around but it can be done.
Albert Einstein:
Fords in the Park 2010
