26-03-2007, 12:19 PM | #1 | ||
Hi,
I have just purchased a 2001 Ford Fairmont GHIA AUII series car. The existing tyres are all pretty well worn, so I wanna replace them with a set of low profile, "sporty lookin" tyres (will keep existing wheels). Just wanted to get your thoughts on what would be best on a car such as this? Prepared to spend upto $200 per tyre. Got some quotes at a couple of tyre places in Town today. Bridgestone and Bob Jane Tmart. Bob Jane had some Xenon 225/55 R16s on special for $149 which sounded alright. I'm fairly new to all this, and as you can see from my number of posts, new to these Forums. Lovin me new Ford tho! :-) Alot better than me old 91 Nissan Pintara rice burner. regards, Brayza |
26-03-2007, 12:45 PM | #2 | |||
BOSS Pilot
Welcome to the Forums mate
You pretty much have to replace the old rubber with rubber of the same size. The only way you can go low profile tyres is to upgrade the rims size, but I guess you know that already Hankook ventus k102 come in 225/55/16, not sure on price but they look pretty sporty. I have similar Hankook tyres and they were $175ish each and they go great. Might also be worth while having a look through the tyre & wheel tech forum theres bound to be info in there if you do a search. Good luck with it Cheers Luke
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
26-03-2007, 12:57 PM | #3 | |||
I'm a novice when it comes to cars mate - so no! I didn't already know that. :-) Is it costly to upgrade the Cars rims to the appropiate size? Dunno if this helps, but I currently have a tyre size of P215/60 VR16. regards, Brayza |
26-03-2007, 01:09 PM | #4 | ||
P215/60 16 and P225/55 16 are interchangeable. You are not really changing the tyre profile as much as increasing width.
To get an idea, P215 means the tyre is 215mm wide. The 60 means the hight(profile) of the tye is 60% of the width. The 16 means a 16" rims. (So yes, tyres are measured in mm's, %'s and Inches.. weird huh?) Anyhow, 60% of 215 is 129 so that tyres profile is 129mm high. 55% of 225 is 123.75.... tyre profile is 123.75mm high. Effectively you are only reducing the tyre rolling diameter a small amount (10mm to be precise .. used a tyre calculator) which will affet your speedo about 1.5% (it will read a little higher so no worries about speed camera's). Hope this explains it a bit. As for tyres, have a look at Dunlop SP3000a's, a very affordable and grippy wet/dry tyre for 16" rims. A set of these would only knock you back about $600 for 4 tyres. If you are increasing rim size (most sets of rims go from around $1500 to $3500 a set without rubber depending on make, size and finish) then rubber gets a whole lot more expensive.
26-03-2007, 01:09 PM | #5 | |||
BOSS Pilot
Yes it can be costly to upgrade rims depending on what you want. Basically when you get a bigger rim, the tyre you get to fit it is less in profile so that the rolling diameter is pretty much the same as the original tyres if you get what I mean. Maybe if your serious about upgrading rims have a look around and find what you like etc. and just run around on the old rubber for a while depending how bad it is or even get some cheap stuff to keep you going for a while if your wanting to go bigger, otherwise you just have to replace them with some good tyres that are the same size and stick with them. Depends what you want to do really. I upgraded from 15" to 17" a few months back and didnt get much change from $1700, really depends on rim/tyre choice as to what you pay.
Chuck up some pics of your ride too mate Cheers Luke
26-03-2007, 01:21 PM | #6 | |||
While I would like to go for decent low profile tyres, I am not keen enough to be spending another $1500 plus on new Rims. Sounds to me I should just get a decent set of tyres that fit on the current Rims (which I quite like). Another question: You mentioned the 225/55/16 tyres will affect the speedo by about 1.5 %. Will they then also effect the accuracy of your odometer? i.e Kilometres (distance) travelled? regards, Brayza |
26-03-2007, 01:36 PM | #7 | |||
Given your speedo probably already reads about 2km's high anyhow (factory setting is about that) then its really SFA of nothing to add another 1.5%. Remember, from new tyres to worn tires can affect your speedo up to about the same anyhow as the rubber gets worn away.
26-03-2007, 01:58 PM | #8 | ||
I have 245/45/16 Goodyear Eagle F1 steels from Tempe Tyres. Apparently they are "exclusive" to them. Anyone know how this works?. They are the tyres for newish Mustangs and Corvettes. They cost $160 each and better than having a Korean brand.
26-03-2007, 02:21 PM | #9 | |||
Capri GT/TS50/GTR
anyway he has had me try a few diffrent tyres and i will tell you stay away form nankangs, falkens (those zeixs are that bad, slicks are are safer in the rain), hancook, gt radials. you should have a look at fedral 595 supersteels there good tyres. not sure if you can get them in your budget but goodyear eagle f1 GS-D3 are the best tyre i have every used. |
26-03-2007, 07:13 PM | #10 | |||
Blown 5L coming
i was quoted about 2000 for a set of advanti "vivid's" 18" x 8" with a decent set of tyres. vivids were on special at the time though.....
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
26-03-2007, 08:10 PM | #11 | ||
I can thoroughly recommend the Hankook Ventus K104 or K102, and the Nexen NS2 sport. I have the first set on my XR8, and the second on the I6 wagon. Both are very good all round tyres.
26-03-2007, 08:18 PM | #12 | ||
Big thanks to all who have replied in this thread.
Lots of good info to take on board and follow up on.. However, I'm thinkin that for the time being that i will just replace the tyres that need replacing with a 215/60/16R tyre, and worry about the low profile stuff down the track. Could better spend the money on other stuff right now. So now i just need to shop around for a decent 215/60/15 radial tyre. Suggestions? regards, Brayza |
26-03-2007, 08:28 PM | #13 | ||
Same as above, but in the same size you are after. Try bob jane, beauies, bridgestone, tyrepower etc etc. Let your fingers do the walking (yellow pages)
27-03-2007, 02:49 PM | #14 | |||
I am sure you will be offered a wealth of knowledge from members in the Trade It certainly helped me with my decision Cheers Autocade |
27-03-2007, 04:22 PM | #15 | |||
regards, Brayza |
27-03-2007, 04:38 PM | #16 | ||
Hi and welcome feel free to post up a pic of your new car..... The tyres that I would recomend in that size would have to be a (a)Dunlop 3000a which is a silica based tyre heaps of grip allround and a comfortable ride (b) GoodYear Excellence another good tyre, are standard now on the new BF Fairmonts, this size is in a 225/55/16 and should fall a bit under the expected $200ea....... Hope that helps you out
Its not peer presure..........Its just your turn! XE project underway |
27-03-2007, 06:25 PM | #17 | |||
Audi S3
I HAVE THOSE TYRES!! noisy as all buggery. fairly grippy though. unless you are really giving it a go.
27-03-2007, 06:30 PM | #18 | ||
All Bran = Regular Member
Anyone used 17" Maxxis?
They were on a car I bought a few years ago and even though 80% worn performed well. I replaced them with a name brand but wish that I'd kept the Maxxis. I'm going to Tassie in June and want to replace my tyres for the trip... |
27-03-2007, 06:40 PM | #19 | ||
All Ford Club Life Member
don't do it , going to tassie you will want the good stuff, plenty of winding roads and if its cool enough icey stuff too' go asymetrical or directional if the budget allows
and if its hang the exspense give me the best, go the g/year F1 GSD-3 I did........
Worked AU XR8 Ute - Toy Std FG XR6T Ute - Daily Supercharged BA 6 Ute - Wife's daily 351W F150 93 XLT 4x4 Supercab |
27-03-2007, 08:20 PM | #20 | |||
Walking with God
Downside is they are the noisiest tyre I've ever had. I won't be buying Maxxis tyres again. Next time I'm going to try Toyo Teo Plus. About $160 per tyre in 225/50/16. Made in Japan, supposed to be really good. Cheers, GK
27-03-2007, 10:47 PM | #21 | |||
I thought that the Maxxis that I had were directional - but I may be wrong I was less than interested in cars at the time... They weren't noisy but that may be because they were fairly well worn. I'll look into the Toyo's (back in the 70's they rivalled Michelin for excellence on truck steer tyres) as I have confidence in their quality. Really only a matter of wear and noise from there ;) edit: oh btw George, we swapped suspensions over on the weekend. The touring setup rides much better and is much less abrupt than the xr setup. I ended up cutting half a coil of the rears... sits level now, much better - I may have to weld the bit back on when we next go away; I don't know how it will sit with a boot load of stuff, lol. |
27-03-2007, 11:41 PM | #22 | |||
28-03-2007, 01:00 PM | #23 | |||
Anyhoo rang Bob Janes and $850 sees 4 x MA-Z1's, balanced, fitted and front and rear wheel alignment. We've got a 800km round trip up country before we head off to Tassie so I'll see what the Maxxis are like. If no good (for whatever reason) I'll stick them in the shed and try something else. I really don't want a 2 week trip on tyres that try my patience. Thanks for the tip... |
29-03-2007, 09:07 AM | #24 | ||
Spin 'em Habib !
Mate , If i Can Travel Tasmania Safeley on Turanzas , Maxxis Will be Fine , I HaD THE turanzas up hills and on ice and they still worked fine for a Crap tyre , and they only had about 15% tread left !
AU2PWR |
