I wont see 160rwkw without a Chip or ECU change
I pretty much made same power as the 1636, with the 1636C977B, but with a better A/F Ratio & bit more Torque which should result in better track times. My car with EDXR6 ECU + XR6 300KPA Fuel Pressure Reg is Leaning out at the end of 4th, i wont make more power even with a bigger cam, without a chip or engine managment, SHATTERED! Ahh well The Car doesnt lean out as bad as the 1636 did, and it leans out LATER in rev range which should help track times, but for power, im maxed with this engine management... Bring On Calder!! ![]() ![]() - Grechie
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
The one and only
Grechie, what injectors are you running?
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Nice work.....what about putting some blue top injectors in? Would that help or make it run rich in the lower revs?
Good work man, nice results
A Unichip or Flash tuner should get it running a bit more power and see some better AFR's Should run a pretty decent time, although your last one wasnt too bad either! |
#5 | |||||
I will look into that CAPA thing for the E Series now... but yea thanks i hope to beat that time ! cheers - Grechie
The one and only
If ya running out of fuel and the injectors are at max, then bigger will help.
#7 | |||
- Grechie
Get it on the dyno and get the operator to measure injector duty cycle.
Anything over 85% is starting to get beyond safe. |
Tuned @ Pitlane Frankston
Grab some AU Blue tops and an XR6 regulator. They flow a bit more, might be good for an extra 7-8rwkw..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
#10 | |||
hey i already have a XR6 fuel pressure regulator, so all i need is the AU Blue Tops, sorry, but were are they found, which AU's ?
get your hands on a set of bosch 775 (blue tops) they come out in GT's, Sprints, HSV's, and 4cycl magna's. Try your local wreacker.
#12 | ||
thanks gunns, do you happen to know what lb these run at ?
#13 | |||
#14 | ||
The only thing is, it won't have a huge effect until you get a chip and tune to use the extra fuel properly.. It'll run rich down low and give you a bit more fuel later on in the rev range..
#15 | ||
ok thanks guys, so...which type is better, bosch 775 (blue tops) or the AU Blue Tops? i know i will need a chip eventually, but for now im looking for a quick easy fix for my leaning out at 4500 onwards.
#16 | ||
If your O2 sensor is working properly the injector size should not matter, as the O2 sensor will detect there is extra fuel getting in and shorten the injector pulse to bring AFR's back to normal, that is the whole reason for having the O2 sensor to control the AFR's
#17 | ||
i have a brand new oxy sensor i bought recently from repco (like 3 weeks ago) , dave (SLOWEA) recomended it
#18 | ||
Just don't go throwing 30 or 40lb injectors at it cause it will be outside the ecu's clabration range
#19 | ||
I think the AU blue tops off a standrd AU I6 are only slightly bigger than standard. 21lb?
The Bluetops are 24lb and deliver quite alot more fuel..
#20 | ||
[EBGLT]
Nice work grechie wolf is your friend.
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
#21 | |||
hey ! So the bluetops will run @ 24lb? or 21lb? i was under the impression that XR6 ecu + fuel reg runs the standard injectors @ 21lb.
#22 | ||
very nice
so is it worth getting the 1636c977b over the 1636? Damon
EBII XR6 5 spd
>>MY CAR!!<< Pacemakers, 2 1/2 Sports Exhaust, Thermos, XH Snorkel, KnN Panel Filter, Custom Black Interior, 18x8 Speedy Graphites with King Super Lows.. and more mods to come! JVC Touch Screen Head Unit, Front - Pioneer 220w 6" splits, Back - Pioneer 220w 6" (all amped), Pioneer 12" 1000w sub, Powered by Pioneer 800w Mono Amp 127.51rwkw |
#23 | |||
so does anyone know, is the AU Blue Tops 24lb or 21lb? and can i get them from ANY AU series...
#24 | ||
Nah Grechie.
There are two different kinds. There is the bluetops, as specified by Gunns which are from AU XR8 engines, magna's, etc. Then there are the AU injectors i was talking about. They are all blue, and physically smaller than the E-series I6 injectors. They are from AU I6 engines. And flow more than the e-series injectors. Try the AU ones first, then grab blue tops with engine management as the next step.
#25 | ||
V8 Turbo Hoon
does your fuel pressure stay constant when its leaning out? may be your pump too if it hasnt been replaced for a long time.
#26 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#27 | ||
so there .63lb better
#28 | ||
yeh grechie, but dont forget, to do it right you would go AU XR8 Bluetop injectors (24lb) and a unichip of some sought.
Dave (Thanatos) had roughly the same setup as you and managed 175rwkw(?) with a unichip and the bluetop injectors.
#29 | ||
Smile
They wont be big enough for your application.They flow 200cc/min. You need 249 cc to produce a but more power.It should idle ok as its not a huge change.Talk to powerflow injection.Theyll give you what you need.
#30 | ||
Smile
Set a realistic goal.Going to big will have the car give more top end power but be a can of worms to tune low to midrange and idle.
