Old 08-03-2007, 03:21 AM   #1
ebfalcon13.5
grey bumperz
ebfalcon13.5's Avatar
Default economy switch
this may be a stupid question but ive wondered for a long time and i know it makes it more "economic" on fuel but what does it actually change
EB with sik exhaust and subs and XC falconsik is a banned word?(needs new motor)
ebfalcon13.5 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 08:14 AM   #2
naughtyfalcon
it changs the shift points of the transmission.
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 08:41 AM   #3
LTDHO
The one and only
LTDHO's Avatar
Yup sure is... Ha ha, just joking.
Yeah as naughtyfalcon said, it only effects the shift points in the trans.
Tuned by CVE Performance
Old 08-03-2007, 01:25 PM   #4
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
when u say shift points. u mean at which rpm the change takes place?
is there any way to mod the POWER mode so its even higher RPM before a change?
brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual
Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter
BRADMAN is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 03:14 PM   #5
ebfalcon13.5
grey bumperz
i had a feeling that was what it does ... i havent been sure though yeah is higher rpm changes possible
Old 08-03-2007, 04:02 PM   #6
EA2BA
PM me if you want
EA2BA's Avatar
economy = less rpm gear change and it thinks about kicking down if it feels like it
power = higher rpm gear change holds gear better, and kicks down when asked
Old 08-03-2007, 04:20 PM   #7
ebfalcon13.5
grey bumperz
thanks, my car has a seperate trans controller is there any way to adjust shift points
Old 08-03-2007, 04:26 PM   #8
EA2BA
PM me if you want
EA2BA's Avatar
simple answer no. You could buy a trans controller thats programmable but personally the cost is bit much for what it will do.
If you get hold of a GHIA trans computer you will get better shifts.
Old 08-03-2007, 07:30 PM   #9
webby_191189
low wagooon
good for towing heavy stuff
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 11:38 PM   #10
smally289
growing up is optional
smally289's Avatar
You can wire in a 'shift kit', available on ebay, or make your own. Do a search on here or look on fordmods.com
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 02:51 PM   #11
ebfalcon13.5
grey bumperz
i might look for that ghia trans controller .. i was at the wreckers today ... should of grabbed one! ... is there anything i need to worrie about in the swap or just unplug..plug and thats it
Old 09-03-2007, 03:13 PM   #12
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
get one that suits your car so mpfi 4 speed auto 4.0 or 3.9 with or without smartlock
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 04:05 PM   #13
poomba
xc - my other love
poomba's Avatar
the economy switch also makes the stall lock up earlier - pretty sure anyway
Power = Money
How fa$t you wanna go??
apparently pretty fast - 400rwkw BF xr6t!
FG F6 bottom end - GTX3582 - Nizpro 4" exhaust - Nizpro cooler - plazmaman intake - piping - plenum - batt relocation - injectors - surge &044 pump - valve work & valve springs - XCAL
poomba is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2007, 02:17 AM   #14
ebfalcon13.5
grey bumperz
i thought shift kits strengthen up the auto for column shifting
Old 10-03-2007, 11:00 AM   #15
naughtyfalcon
they do for all 4 speeds.
2000 AU Wagon
Old 11-03-2007, 12:39 AM   #16
eb_razy
Modified Ford Club.org
eb_razy's Avatar
The power mode lets the engine rev 3000 rpm more before gear change at half throttle. Ive tested it at different speeds.
-Ford, Honda, Kia and Volkswagen mechanic -
-DECEASED-1993 EB II Fairmont - Lastest - 1994 ef xr6 - 5 speed manaul - PDW 5 spoke 17s - genie 6>2>1 extractors - straight through exhaust - More to come
eb_razy is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 11:18 AM   #17
niko
likes falcon's
niko's Avatar
if you want economy don't take it over 1500-2000rpm and do it gently you practically are tickling the throttle if you want to save juice....lol
www.carhubsales.com.au
Old 12-03-2007, 01:40 PM   #18
castek
you want it to change later in normal mode? mine changes at 5500rpm in normal. i dont really think you'd need to rev it that much to get power out of it
castek is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 12:04 AM   #19
ebfalcon13.5
grey bumperz
yeah, i do .. how did you get it to do that
Old 14-03-2007, 12:14 AM   #20
holmsy
holmsy's Avatar
mine does that. it screams before changing wether its in perform or economy
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 12:44 AM   #21
ebfalcon13.5
grey bumperz
mine doesnt !! although my old ea 3spd used to scream pretty good i want it to be like that again haha
