What Wheelspin?
does anyone have a Wade 1521a cam they would like to sell me?
![]() i would buy one from wade but they dont have any billet. i need one to run with the headwork and compression increase i have just done. the crow 549 isnt big enough any more ![]() cheers guys. :eclipsee_
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
The one and only
I'm pretty sure GTHOFAN is our Wade cam supplier.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
rofl copter
just go a 977b, they are a very similar cam to 1521a just a touch smaller, and only 120
GQ patrol.
.... thats all |
EBII XR6
$120 for a wade 977b? Is that brand new straight from Wade? Sounds like a good price. How much would it cost to get a cam from a wreakers and get a re grind to similar specs?
DEVLXR
cam from wrecker $50, regrind is 120 if u say you are a fordmods member
I have said it before but you can get the 1521a in a regrind speak to kieth there i was talking to him only yesterday and with the base circle on a standard cam you can go as large as 292 tho before it needs to be billet.
Also note the 1521a is a good cam but if your car is rev limited which i am guessing it isnt by now its useless and also it was actualy made for jason gillets gas turbo set up so there may be a wilder cam out there that would suit your aplication better. |
What Wheelspin?
the 977b is a fair bit smaller in the duration than a 1521a. and a bit smaller in the lift. i need more duration.
yer, the 1521 has a higher lobe sep, better suited to turbos. if it could be ground with a 110lsa it would be a better performer me thinks. also my car is not rev limited.
one day
just buy a regring and use shims its so much cheaper
XY GTHO MOCK 406 cleveland grout filled, pavtek alloy girdle scat 4340 crank, scat h beam rods 2000 series bolts CHI cnc 2v heads comp 308r solid roller camshaft torque power single plane manifold 950 quickfuel race carb pro trans c10 with transbrake 5500 tce converter 3.89 diff gears |
I have a 1521A Lsa112 but its staying in the car, sorry...
Quote: Originally Posted by XCPWSF Is there portable speed cameras? Because coming home from school I noticed a cop sitting on the corner, with some box with buttons and knobs, with wires running into one of the big gum trees. Just practicing with the Tazer on a Koala? |
Interceptin'
Ive got a stocko cam for sale out of my ef perfect for a regrind. pm me.
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
Gunna girlie-man
yes we have billet avaliable now
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
#12 | ||
rofl copter
woah go go billet
GQ patrol.
.... thats all |
Gunna girlie-man
although there may be something with 560 lift at the lobe
#14 | ||
MADED.6
dam if so i will most likely get one. also would this cam go better than a dev5 i am not overly impressed with it.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
#15 | ||
the 992A has 588 vlavle lift and kieth soomed to htink he should be able to do that on a regrind howver you wouldnt be ablet o shim it youd need to machine the rocker pedistals to suit. sing out if you want the specs on it.
#16 | ||
Two > One
1603 is also nice
#17 | ||
What Wheelspin?
1603 is too small. i just want bigger than i have now (crow 549) but not as big as the crow 546 i had. that was way too big for my motor. tuning was a biitch!
because i have the chiptourqe, it will run a 1521a no worries. so thats what i am aiming for.
#18 | ||
What Wheelspin?
also for anyone who wants to know, the 992A has 590" lift, and 214degress duration @50
#19 | |||
What Wheelspin?
sorry, i got that mixed up with the 1604....
#20 | ||
Two > One
1603 is as big as the 546 you removed
#21 | ||
MADED.6
howe much power are u making walkinshaw. and mr 4.0 wade has more billet now so u can get 1 made up.
cheers josh.
