Old 25-02-2007, 10:43 AM   #1
Glend
Default Indicator problem
We are experiencing problems with the indicators on our AU11 2000 Fairmont,
It seems they don't want to work when the engine is cold eg, first thing in the morning even when the car has been in a garage over night. We indicate right for example and the indicator light comes on and stays on! and wont intermit on and off. Other times they run fast then slow (in the same 30 secs).
At other times they work normal.
We thought that maybe moisture had gotten inside the relay box or something, not sure really, does anyone have any clues for us?
Glend is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:11 AM   #2
au2sw
Blown 5L coming
au2sw's Avatar
perhaps check the flasher can, maybe in need of a new one?
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:19 AM   #3
Glend
Default Flasher can
Excuse my ignorance but what is a flasher can and where would i find it?
is it the flasher relay, 1 inch square Black plug in the fuse bos under the dash?
Old 25-02-2007, 11:36 AM   #4
au2sw
Blown 5L coming
au2sw's Avatar
that could be part of the problem, just thinking about it though and im not sure if newer cars have a flasher can as such, i think they just use the flasher relay now. i know older cars had a flasher can. it makes the indicators flash on and off and is usually located under the dash on the drivers side.
Old 25-02-2007, 11:48 AM   #5
Glend
Thanks for that, we just noticed that when we push slightly on the flasher relay while the indicator is on the indicators start flashing when we let go it stops flashing. We'll try a knew relay switch and see what happens.
Old 25-02-2007, 11:52 AM   #6
au2sw
Blown 5L coming
au2sw's Avatar
no probs, fordforum/aufalcon to the rescue again
