Old 23-02-2007, 11:50 AM   #1
AUIIISR
AUIIISR's Avatar
Default Tyre wear, whys it happening
Ok so my AU3 is lowered by with pedders, its has a Camber kit installed, I pulled the front left tyre off yesty to work on the brakes n ive noticed that i have wear on the inside of the tyre, about 1 inch wide and has almost worn to the material, and isnt a uniforn wear all the way round.
I had a gander underneath and all i can figure is it is rubbing on the top control arm (dont quote me on terminology here), this confused the hell out of me cause isnt it supposed to be moving with the rest of the suspension and as such wouldnt rub like it has?!?!?!?!, anyone had this problem, or recommends a way to rectify may help
PS. its not negative camber either, and is only on the front left
AUIIISR is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 12:17 PM   #2
needaXYGT
AU II XR8
needaXYGT's Avatar
well if its not rubbing on anything, then the only thing that can be happning is the wheel is not 90deg to the road?
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 12:29 PM   #3
AUIIISR
AUIIISR's Avatar
the only thing that I could see that it could rub on is the upper control arm, it lines up perfectly to where its wearing but i cant figure why it would because its meant to move up n down as does the suspension
Old 23-02-2007, 12:31 PM   #4
GXL078
GXL078's Avatar
They did that from new with factory tyres and no modifications.
GXL078 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 12:40 PM   #5
AUIIISR
AUIIISR's Avatar
lol, well thats ******
Old 23-02-2007, 12:57 PM   #6
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
camber isn't the only thing that will wear the inner edge. What is your toe in measurement? Sounds like yours could be toeing out.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 01:11 PM   #7
JefXR8
JefXR8's Avatar
go get a decent wheel alignment
If there is a problem they will tell you.
This is not something that you can fix yourself.
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 01:26 PM   #8
ronwest
All Bran = Regular Member
Agreed.
Some wear explanations here. There are may others on the net...
http://tinyurl.com/tug7e
Old 23-02-2007, 01:53 PM   #9
AUTickford
XD197
AUTickford's Avatar
Just got a suspension check done by pedders on my eb and they said it was fine.Well i got home and jacked it up to find the upper control arm bushes almost completely gone with about 10mm play.I rung them back and they said it was hard to tell if they are ****** without pulling it apart so they just ticked it off as fine coz its easier for them, too bad he said. id say pedders has ****** up again with your car coz they employ monkeys to do their mechanical work and probably pay them peanuts also :togo:
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 03:35 PM   #10
AU dude
Flying high...
AU dude's Avatar
Pedders = Alot of Bulls**t
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2007, 04:32 PM   #11
Mechan1k
Mechan1k's Avatar
I went to Wholesale Suspension at Penrith and they put mine on a suspension tester on a 4-post hoist and showed me where my ball joint was stuffed and also showed how old my control arm bushes were. Very comprehensive indeed.
And their alignment guy took the time to do my alignment properly. Asking me all sorts of questions on my tye of driving ... how much load I cary in the back ... what sort of roads I travel along .. etc.
In the end .. I was impressed with the alignment (and the work done by them as well) The ute has never driven so nice and smooth on the road since I have owned it :hihi:
Old 23-02-2007, 06:23 PM   #12
mik
mik's Avatar
get a front end check, that will take the guess work out
Old 24-02-2007, 04:37 PM   #13
GasoLane
Former BTIKD
GasoLane's Avatar
If it is rubbing there should be wear marks, or very shiny suspension bits, where it's actually touching.
Old 24-02-2007, 06:20 PM   #14
AUIIISR
AUIIISR's Avatar
I have pedders, put in can b4 i bought it, but I dont get my Suspension and steering checked by them, Canberra Capital Steering and Suspension have looked after me with every car ive owned and I will continue to go back to them
Old 25-02-2007, 10:51 PM   #15
blackers10
blackers10's Avatar
i got a full alignment done at pedders after chewing thru a set of front inner edges and the front left is doing the same AGAIN!! got an alignment booked in tommorow from pedders (dont want to have to shell out more cash for somthing they scewed up!! )
next time im going to drivesafe or redcliffe springs and suspension who did AU_Fairlane_Man's(white au lane) car and it rides nice as! with ultra lows and 19s
Old 26-02-2007, 05:17 AM   #16
5tumpy
It'll be wheel alignment, almost certain. I'd go to the local tyre place, buy a new set of fronts, keep the good tyre for a spare, and have an alignment done at the same time.
Wouldn't trust pedders as far as I can throw them, too many bad stories! Don't go to Ford for a wheel alignment either, they are just as bad!
5tumpy is offline   Reply With Quote Multi-Quote with this Post
