Old 17-02-2007, 06:24 PM   #1
Stav
Smile
Stav's Avatar
Default A little urgent help please bbm?
Guys I decided at 5pm to remove my cylinder head.Everything is off but the broad band manifold,rockers and head bolts.
What is the best way to remove the broad band manifold? Any and all input will be appreciated.
Old 17-02-2007, 08:30 PM   #2
V8falcons
V8falcons's Avatar
rachet spanner,or 1/4 rachet with extension bars and busted nuckles
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 08:44 PM   #3
Krytox
Krytox's Avatar
10mm dwarf spanner!
CareFree....
we may not be No.1 but we're Up There
Krytox is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 08:57 PM   #4
AUTickford
XD197
AUTickford's Avatar
Can you leave it on until the heads off then it will be piece of **** to remove
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 09:34 PM   #5
AUXRVIII
Get yourself a 10mm ratcheting ring spanner, it's all you need to undo the manifold from the head before removing the head. You can leave the manifonld sitting in place after unbolting it from the head, no need to remove from engine bay.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 10:02 PM   #6
TwistedEL
TwistedEL's Avatar
Will a ratcheting ring spanner fit in there? I doubt it, a normal ring spanner barely fits.
I use a ring spanner and a lot of patience.
Old 17-02-2007, 10:25 PM   #7
Stav
Smile
Stav's Avatar
Just those back bolts seem to be difficult. The first 3 intake runners are accessible by hand from the front. I want to leave the manifold there in the engine bay.Even though it looks difficult there alot more work to remove it with the head. The back injctor wiring loom is obstructing access to those last bolts ..keep the ideas coming.How would I access those rear manifold bolts? Or is it a case of just keeping at it?
Old 17-02-2007, 10:33 PM   #8
bodes-sh
can you get to them from underneath?
Old 17-02-2007, 10:33 PM   #9
Stav
Smile
Stav's Avatar
Oh nice bastar I am.... thanks so far gentlemen..if you have more suggestions please do..
Old 17-02-2007, 10:38 PM   #10
AUXRVIII
They sure do, have done it many times. I used to use a 1/4 short ratchet with socket but ratcheting ring makes it really easy.
Quote by bodes-sh
Yes.
Old 17-02-2007, 10:40 PM   #11
AUXRVIII
You can twist the injector to give more clearance.
Old 17-02-2007, 10:46 PM   #12
bodes-sh
i just had a look and it would appear that you can reach around behind the manifold, ie at the firewall (depending on the size of your hands, lol) to get to the last bolt at least, the bottom one on number 6, the bottom one on number 5 seems to be easiest from straight on top
Old 18-02-2007, 08:53 AM   #13
Stav
Smile
Stav's Avatar
Thanks guys.I woke up at 630 ,had breakfast nd out I went. I undid the bbm with a mini socket wrench and 10mm socket and 10mm spanner.The rockers are off the cam tensioner is out,cam cable tied and the guide head bolt at front is semi undone. I am at the head bolts now. They wont budge!!
I know they are 14 mm socket but I am going to supacheap to get some ratchet spanners, aset of impact sockets,various length extension bars. Is is 8:49 I am going well!! Its hot alreaady though but waer is close at hand. Im gonna jump in the car and get some tools.Damm head bolts!!
Old 18-02-2007, 09:55 AM   #14
Stav
Smile
Stav's Avatar
At this stage the head bolts are all that are left.However they are not budging. In the next 30 minutes I am going to decide to just put it bak together again.The bolts seem like 14 mm bolts. The 3 14mm sockets all have a little play in them ..The imperial bolt has paly as well.I cannot remove any of the bolts.One has gotten slightly rounded.I am going back out to reassmble everything and leave it as is. This is the first head I cannot remove..
Old 18-02-2007, 10:10 AM   #15
jonbays
TL40 Wagon?
Don't give up Stav those bolts will come out.
Check the head size on your new head bolts carefully. You do have some new ones don't you? You will need new ones as they need to be replaced!
Big hammer downwards hit to the head of the bolt without deforming it will help release the tension in the bolt and then it's big bar and carefully applied brute force.
Don't snap them off though!
Old 18-02-2007, 10:33 AM   #16
FS5
its realy a 2 man job to get these buggers undone i've done it twice on mine now.see if one of the forum members can come give you a hand .you need one guy to keep the socket on the head bolt square while the other swings off the breaker bar and busts a whoofer valve.
i found a 14mm imact socket worked the best.
don't give up your nearly there
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 01:51 PM   #17
Stav
Smile
Stav's Avatar
Well I did persist for 25 minutes.I wish they would come off but they did not. The car is back to normal again.It feels quicker ironically.Alot more solid quieter and its goit me stuffed why? Maybe it liked the new gaskets? I dont know? One thing for sure though..the standard heads ports are much smaller!!! I dont feel mad funnily enough..I feel good. Jon Bays I have the new bolts ready,I had everything perfect .I even learnt about the tensioner full on and installed that 100% I have not done what I set out to do but I am still proud that I gave it a go. I need the car for work tommorow and it is ready. At least I can go to work. Its not like I catch the train ,bus or ferry to work so I will definately get someone to do this.
It is very odd though that its much quieter and feels faster? Midrange is punchier?I dont know what has happened but it is noticeably quicker with the same old parts on it.
I still want the head on but I am getting someone to do it for me.It was a bugger with those head bolts...no socket fitted 100% tight on them and I went and bought a stanley set as well which did not work.
I have done aroud 4 e series heads before with ease but this au head just would not budge.
Thanks any way everybody.Your advice and well wishes showed me the power of ford lovers!! Thanks again!
If I had no work on tommorow I would hae left it and got someone to remove them.
Old 18-02-2007, 02:04 PM   #18
Stav
Smile
Stav's Avatar
I can only assume that someone someday may do a search and use this thread so as fr as the bbm bolts go you can get the first 3 -4 bottom bolts from underneath.You need a 10mm spanner,1/4 inchsocket set with 10mm socket,ratchet spanner 10mm helps some to. Most of these are accessed from underneath.The last 2 bottom bolts are accessed from the rear firewall.
Old 18-02-2007, 03:50 PM   #19
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Well Stav maybe the bolts are trying to tell you some thing, i'm working fine so leave me alone :
Well that good to hear you got it back togetter & it run better. Do you clean any up while you had it apart. Maybe you put it back togetter better than before. :
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 04:07 PM   #20
Stav
Smile
Stav's Avatar
Maybe it did go together better ? Well I have made a decision to give it another crack The difference next time will be that I will be using an angle grinder to shear the bolts.This way the head should come off and the bolts undone wit multigrips.
I think the seat of my pants boost is just everything settling down to be quite honest
Brett I can smell a better et with this worked head.I think today is my preparation for the real thing..lol never say never!!!
Old 18-02-2007, 04:26 PM   #21
Whoosha
AU DIE HARD
Whoosha's Avatar
Gees Stav your persisant if nothing else : those bolts probabley came from the same batch as Caspers wheels studs... anyway good luck with it mate :Reverend:
Originally Posted by Riksta
Old 18-02-2007, 04:32 PM   #22
AUIII XR8 MAN
DJR TM#54
I guess the grinder will take care of any bolts that want come undone.
Lets us know when your heading out to WSID next time & i see if i can make it.
Old 18-02-2007, 05:05 PM   #23
Stav
Smile
Stav's Avatar
For sure!
Old 18-02-2007, 07:50 PM   #24
AUXRVIII
If your detemined to remove the cyl head the best way to tackle the head bolts is to first get a new set, then get a decent size hammer and peen over the edges of the head bolts so you would have to tap on your single hex impact socket with a hammer, clean the oil off the bolts with carby clean & use a 600mm breaker bar to crack the studs loose.
Old 18-02-2007, 09:00 PM   #25
Stav
Smile
Stav's Avatar
I think this was my shortfall today.The fact that a 14mm impact socket will do the job where standard sockets just done cut it. I am very determined to change this head as I am pretty sure the new head will make the wagon go seriously quick.
The next time though..I will have anew set of impact sockets,a few grinding wheels and make it a long weekend thing. I didnt leave myself enough time.Essentially not even a full day. The fact that I need the car tomorow for work forced me make a good decision and I think that I did. I will be much quicker next time as I have had the practice.
The other thing is that the car is screaming..??? In 30 degree heat it normally doesnt go so well bordering on bad.However since putting everything back together it feels as fast as the middle of winter.I am very tempted to wait for cooler weather just to run it as it is.It is going very good for no apparent reason?
Old 18-02-2007, 11:38 PM   #26
bodes-sh
are you sure you didn't add a turbo or supercharger to it while you were under the bonnet lol?
Old 19-02-2007, 08:07 AM   #27
Stav
Smile
Stav's Avatar
I think the xhaust and inlet are sealing better.Also the temperature gauge reads cooler for longe.It might just be the tightened hoses ? I dont know but I have seen mods that people advertise which dont feel as good..lol :lookedat:
Old 19-02-2007, 08:36 AM   #28
Mechan1k
Mechan1k's Avatar
Stav .... now you know my pain ... I had the same issues when trying to remove the head bolts. Ended up rounding several and snapping a few. In the end ... I just replaced the engine for a newer one ... along with a new auto at the same time.
I needed the car back on the road and I wasn't going to fiddle around with trying to get head bolts out that refused to budge ... oh ... I was using impact sockets as well ... and has 2 other mechanics have a go at it as well ... and they said the head on the old engine was a herdest one they had come across.
Old 19-02-2007, 10:26 PM   #29
Stav
Smile
Stav's Avatar
I spoke too soon.The car has been going like a bullet!!! Until 2pm when the lifters went all noisy and the idle went to buggery.I have just spent another few hours changing lifters and what have you. Finally it decided to work well but only when taking it easy. I think the oil pump somehow is going or Ive stirred up crap in the oil system? Either way I am going to drive easy tommorow and see how it goes.
Old 19-02-2007, 11:44 PM   #30
Ruger
Bseries Moderator
Ruger's Avatar
when it comes to engine internals you gotta be super clean. a piece of dirt lodged in the wrong place and you can lunch the motor. keep an ear out for bottom end bearing noises, dirt loves scratching up the bearing and ruining them.
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
