Old 14-02-2007, 10:49 PM   #1
kaceb
Default AU3 cruise?
I have sourced a few parts towards fitting cruise control to my Au3
indicator / wiper stalks
small motor module thingy
steering wheel buttons ( although I may need more steering wheel buttons as they are slightly damaged )
what else do I need?
someone has tols me there is a brake pedal switch?
I all the wiring already in the car?
any help will be greatly appreciated
kaceb is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 09:43 PM   #2
kaceb
Someone on here must have fitted or played with cruise control??????
I am hoping to fit it , but feel that I need some advise first
Old 20-02-2007, 09:45 PM   #3
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
what AU3 is it ?
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2007, 07:20 AM   #4
james22
With da Warlords
james22's Avatar
is it auto or manual? If manual you'll need a clutch switch too
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 21-02-2007, 09:23 AM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
ive never seen an AU without CC , thats why its weird
AU2PWR
Old 21-02-2007, 02:37 PM   #6
HOTC2R
Forte didn't get cruise as standard
HOTC2R is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2007, 08:09 PM   #7
TwistedEL
TwistedEL's Avatar
If it has ABS then all the wiring is there
You will need a brake pressure switch for the master cylinder
If it is a manual you will need a clutch pedal switch (if it is auto you may need to bypass the clutch switch by shorting out 2 pins in the connector for the clutch switch)
It should be that easy.
Old 22-02-2007, 11:41 PM   #8
all4fordau
try this mob. geat advise and a huge range of parts
http://stores.ebay.com.au/id=1338757...TRK:MEFS:MESST
all4fordau is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2007, 04:47 PM   #9
kaceb
ok guys thanks for that
its a 2002 au3 AUTO forte and yes it has ABS
And I do need to find some steering buttons as the ones that came with it are fooked
Old 24-02-2007, 04:57 PM   #10
mattbl
mattbl's Avatar
You need the cable that goes from the cruise module to the throttle and there is a wiring harness that hooks up the module. It runs through the fire wall and plugs in behind the fuse box in the cabin.
You pretty much have it all then as far as I can remember. Hooking it all up is pretty easy.
There is a good write on problem solving cruise at Fordmods. It was written for the late E series but its pretty much the same.
2006 BF Egas XR6 Ute. Bone stock - Sorry Fellas I've had a set of King Springs in the garage for 12 months who knows when I'll get around to putting them on :
mattbl is offline   Reply With Quote Multi-Quote with this Post
