Old 07-02-2007, 08:46 PM   #1
maxford
Default AU III; 100km against strong winds problem
This is second of the intermittent faults that I had in the past with my AU, It kind of went away, but I am scared it might happen again when I go for longer trips.
When driving around 100k/h or more on the freeways against strong winds, the engine will sometimes squeal and you have feeling like with that noise the car looses speed or power, therefore the car will slow down and the noise will disappear ..till next time again and again
I had a feeling that it could have something to do with bearings on the cooling fans.
Does it sound like a theory?
maxford is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2007, 08:56 PM   #2
Mechan1k
Mechan1k's Avatar
Are you getting overheating issues when the car is labouring against strong headwinds???
The thermos have been known to sowly die over time .. I just replaced mine at 200,000km as one of them was barely working.
Is yours manual or auto????
Another thing I thought of is your serpentine belt might be slipping as well ... any oil leaks at all???? Is this with A/C on/off???
Just trying to ascertain why it could be happening.
Old 07-02-2007, 09:02 PM   #3
maxford
Car never overheats, has travelled 80,000km, no major oil leaks (now that you mentioned, little one in the front of the engine) This happens with or without AC. CAR is auto...
Old 07-02-2007, 09:11 PM   #4
mik
mik's Avatar
could it be the power steering pump labouring causing the belt to slip?
Old 08-02-2007, 04:08 AM   #5
T-Pak Addict
Jim
T-Pak Addict's Avatar
could be the tensioner pulleys, easy enough to replace
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 02:45 PM   #6
nikos
mezzo forte
Doubt the steering pump would labour on a freeway...
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 05:52 PM   #7
maxford
I will clean up any oil in the front of the engine and talk to mechanic about tensioner pulleys
Old 08-02-2007, 08:44 PM   #8
mik
mik's Avatar
if there was a problem it might.
