Old 19-01-2007, 01:56 PM   #1
blackdiamondbay
Question AUI eng. into AUII?
Hey folks. Need help. Can anyone tell me of any problems involving putting a series 1 engine into an LPG series 2 ex-taxi? Much appreciated.
blackdiamondbay is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2007, 02:58 PM   #2
The Monty
Just slidin'
The Monty's Avatar
I dont see nay problem with that at all. Its exactly the same as far as I know. Maybe the wiring for the dash from the ecu or something but thats about it.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 19-01-2007, 03:17 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
no issue unless one is VCT and the other is normal (but I doubt this would be an issue on your case)
Just use all the sensors from the AUII motor on the AUI motor in case ford changed something stupid, otherwise a motor is a motor by any other name.
Old 19-01-2007, 03:21 PM   #4
Casper
Contributing Member
Casper's Avatar
So if it looks like a motor.. and quacks like a motor... can I call a motor a duck? :
Older, wiser, poorer.
Old 19-01-2007, 03:40 PM   #5
The Monty
Just slidin'
The Monty's Avatar
You can if it has a duck call strapped to the blow off valve.
Old 21-01-2007, 09:24 PM   #6
Tony_4500
I had a aircon pump from a au series 2 fitted to my au series 1 and it was shorter in length and kept throwing the belt. The mechanic had to fit a series 1 aircon pump to solve the problem.
Cheers Tony
Tony_4500 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2007, 10:01 PM   #7
peterban
AULTD
peterban's Avatar
Cheers Tony
Do you have the part number they fitted?
Should be a yellow sticker on it with some numbers.
The reason I ask is that I bought a pump off e-bay for my series 2 but was unaware there were any difference between s1 and s2
Regards
Peter
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2007, 10:18 PM   #8
Tony_4500
Sorry peterban but it was done at a mechanic's shop, they were suprised that there was a difference between the series 1 and 2. Whoever they got the part from exchanged it for the right one and all was ok.
Will look tomorrow in daylight and see if I can see any part numbers for you but as we all know it's hidden away pretty well!!.
Cheers and good luck Tony
