Old 11-01-2007, 05:33 PM   #1
Hellebore
Question engine wont start :( AU s1
Ok i did post something similar in the e series forums..... but its kinda an au-s1 problem
i have just finished putting au gear in my ea.... i mean everything.... swapped out the entire wiring loom engine accessorys etc, and at the same time i am trying to get it to work with my manual gearbox (was an auto AU)
so i have put a resistor in to make it think the temp is correct and another so it thinks it is in neutral.
at this point in time i have got the engine ticking over (not only is there a resistor so the car thinks it is in neutral there is also a switch which i have set to 'park', before that it wouldnt even crank)
there is definatly a spark....
so what is stopping it?
fuel pump is running fine so i can only assume its the injectors but i have no idea why thay wouldnt be firing?
everything is plugged in as it was except for the airbag and the auto.
if anyone has any ideas it would be much appreciated....
all the au gear is from a 98 S1 with smartlock...but there is not smartlock warning light.... the only other light i can see that comes up on the dash when I turn it over is the one that looks like ((!))
sorry if thats i bit hard to read....im going out of my brain
Regards
Cam
Hellebore is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 05:47 PM   #2
superroo
You can't stop the signal
superroo's Avatar
i'm pretty sure ((!)) is the brake warning light.
Personally if it's ticking over, it's more engine related than installation problem. I could be wrong though.
Old 11-01-2007, 05:50 PM   #3
HLC
Audi S3
do you have a manual ECU? that way you wont need the resistor and whatnot
Old 11-01-2007, 05:54 PM   #4
Hellebore
id love a manual ecu but couldnt find one
the wreck i took the engine out of was running perfectly when i took it apart
so its something i have done or smarlock is being dumb....
Old 11-01-2007, 06:02 PM   #5
superroo
superroo's Avatar
if it's smartlock i don't think the engine would even turn over
Old 11-01-2007, 06:05 PM   #6
HLC
Audi S3
keep looking. there will be one floating around somewhere.
Old 11-01-2007, 06:12 PM   #7
Hellebore
so if its prolly not smartlock.... what causes injectors to not fire??
im pretty sure they arent firing.... i cant hear them....
Old 11-01-2007, 07:12 PM   #8
Hellebore
Garrrrr im going nuts...
can smartlock half disable the car???
ie not switch on the injectors??
if so where would you look
Old 12-01-2007, 01:24 AM   #9
EvilChief
Boost Addict
in order to check if injectors are working or not try starting car with carby cleaner, if it fires and "sorta runs" u know u dont get fuel from ur injectors.
use a multimeter to chase down if permanent power is going to the injectors. if there is u can iether use and injector test light to see if its firing or use a long screw driver and rest on an injector and hold ur ear to other side and listen for a knocking noise. if thats that case the needle opens closes and points towards a fuel pressure issue. if there is no noise u can safely assume that there is no signal from ecu to injectors. also check ur timing . check all fuses
that would be my starting point.
also did transfer the smart lock box as well and the barrell?
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 12-01-2007, 02:26 PM   #10
Hellebore
yeah tranfered everyhting
the whole loom
yup injectors are def not firing fuel pump is running.
fuses checked too
Old 12-01-2007, 03:49 PM   #11
EvilChief
Boost Addict
are u suing the au ignition barrell?
the injectors are fired directy from the ecu without relays in between to elimenate delays. do do u have postive 12V current on ignition on on all injectors?
N12 Pulsar - sold
Old 12-01-2007, 05:31 PM   #12
Hellebore
yea im using the au barrel....
ill check the voltage... i thought they only have power if they were firing?
or does the ecu go low to fire them?
Old 12-01-2007, 07:40 PM   #13
Hellebore
Update:
Yes the injectors have power..... so all i need is the ecu to make the damn thoings fire!!!!
i have put a bit of fuel in it so i know the damn thing runs :S
kill me
Old 12-01-2007, 07:54 PM   #14
EvilChief
Boost Addict
lol injector pulse signals are done via earthing, hence a constant charge is delieverd to the injectors, when the earth trigger is activated it closes the loop and u have an injection cycle of x amount of ms.
now next trick is to hold a screw driver ti it with ur on the otehr end and listen for a ticking sound.
i wonder if u may have a crank angle signal issue, but that wouldnt explain the ignition firing. its a little hard with standrad ecus to diagnose. :(
N12 Pulsar - sold
Old 12-01-2007, 08:02 PM   #15
Hellebore
yeah def no ticking i already tryed that
the engine was working before i took it out of the smashed AU
here was me thinking this was gunna be easy 'just plug it all back together and VROOOM' an EAU falcon
lol
Old 12-01-2007, 08:50 PM   #16
EvilChief
Boost Addict
lol never happens mate
ok so now we def know that there is no trigger signal coming from the ECU ... now that makes it nice and hard ...
N12 Pulsar - sold
Old 12-01-2007, 09:01 PM   #17
Hellebore
hard....awesome i love hard
its prolly some obscure little wire not earthed somewhere :| (yes the ecu is earthed)
Old 12-01-2007, 09:04 PM   #18
EvilChief
Boost Addict
the ecu has about half a dozn of earth wires running into it
N12 Pulsar - sold
Old 12-01-2007, 09:04 PM   #19
Hellebore
oh
right...
Old 12-01-2007, 10:22 PM   #20
Hellebore
there is another thing.... when i swapped the steering columns over i have a spare 2 wire plug on the au loom.... has a DB-R and a brown wire
its right near the other steering column plugs but yeah.... no idea
Thanks
Old 13-01-2007, 12:57 PM   #21
Hellebore
been trying to work this out from the diagrams in the gallery.... but the large pic for the fuel injection system is tiny and you cant read the writing
http://www.fordforums.com.au/photos/...php?photo=2292
is there a bigger copy that someone might have?? i kinda need to know what colours the injectore wires are and what pins they go to
Thanks
Cam
Old 13-01-2007, 01:05 PM   #22
TwistedEL
TwistedEL's Avatar
Go down to supercheap and shell out $30 for an AU Gregories, they have wiring diagrams in them
Old 13-01-2007, 02:39 PM   #23
Hellebore
IT LIVES!!!!
i had the fuel pump wires on backwards
LOL
HUZZAH!
Old 13-01-2007, 03:43 PM   #24
TwistedEL
TwistedEL's Avatar
Bahah good on ya mate
Old 13-01-2007, 05:57 PM   #25
Hellebore
phwooooorrrr
way faster than b4
Old 13-01-2007, 06:12 PM   #26
au2sw
Blown 5L coming
au2sw's Avatar
glad to hear u got the girl to fire up. and what lesson did we all learn from this?!!! check ur wiring first!!! lol have fun with the new engine bro
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2007, 03:38 PM   #27
Ford_V8
Well done on the conversion, how long did it take you all up?
Ford_V8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2007, 07:24 PM   #28
Hellebore
ummmmm in straight days prolly a bit over a week (in actual time about 3 months)
i was going slow and i rekon u coulld do it in about 3-4 days if you knew what you were doing and had someone to help pulling eng. etc
Cam
Old 20-01-2007, 07:38 PM   #29
au2sw
Blown 5L coming
au2sw's Avatar
ok, now the engine is done, the go fast bug will bite soon if not already, what other mods u plan on doing to it now?
Old 20-01-2007, 10:59 PM   #30
T-Pak Addict
Jim
T-Pak Addict's Avatar
very interested what you have done as I might be looking at doing the same thing in the near future (looks at engine and trans in the shed). did the loom hook up to the EA dash or did you put the AU dash in it??
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
