Old 02-01-2007, 07:16 PM   #1
kenz
BOSS Pilot
kenz's Avatar
Default Keypad help
Hey guys
I just replaced the battery in my central locking keypad and I was changing from stage two locking to stage one locking and now when I lock it, it puts out about 5 really quick beeps of the horn? I did a search but couldnt find anything. Does anyone know how to fix it, oh and its a AUII
Thanks
Luke
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 07:40 PM   #2
FRDTUF
FORD TOUGH
FRDTUF's Avatar
thats sounds like the noise it makes when one of your doors aren't shut properly & you try locking it...
FRDTUF is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 07:43 PM   #3
kenz
BOSS Pilot
kenz's Avatar
Both the doors are shut thats what I thought it might be aswell
Black BAII XR8 Ute
Old 02-01-2007, 08:08 PM   #4
FRDTUF
FORD TOUGH
FRDTUF's Avatar
you might have to take it to a ford dealer or any one with a scan tool to see if the ecu has lodged any codes...
Old 04-01-2007, 01:58 PM   #5
kenz
BOSS Pilot
kenz's Avatar
Ok ive worked out that its the drivers door lock. It works fine unlocking and locking with the key but when I use the remote it wont open or close properly. Would this be the actuator has gone in it or does anyone know
Thanks
Luke
Black BAII XR8 Ute
Old 04-01-2007, 02:34 PM   #6
FRDTUF
FORD TOUGH
FRDTUF's Avatar
yeah sounds like that, if it works fine with the key it's gotta be something electrical...
Old 04-01-2007, 03:14 PM   #7
Mechan1k
Mechan1k's Avatar
Funny you should say that ... my passsenger actuator died in the ute yesterday ... had to get a complete locking mechanism and replace it ... comes with jump loom as well for the AU ... as the actuators are made with B-series loom ... Ford supply the jump loom for $12.
Not had to change ... need a T30 bit to unbolt the locking mechanism from the door though (3 Torx screw).
I had a grinding noise from the lock when i tried to lock it ... and it stayed open ... causing all locks to stay unlocked ... so i had to replace it (being a work vehicle)
But ... if the key works ... it won't be an actuator ... maybe a sensor for the door ajar.
Old 04-01-2007, 04:01 PM   #8
kenz
BOSS Pilot
kenz's Avatar
Yeah I unbolted the lock from the door and had a bit of a look at it. Its like when it tries to unlock it gets halfway done and gets stuck or something and locks again. And the same thing happens when locking it. It does this with the remote locking and the locking button thats to the bottom left of the dash. It all works fine manually with the key though.
Black BAII XR8 Ute
Old 04-01-2007, 06:14 PM   #9
TwistedEL
TwistedEL's Avatar
Sounds like you need another actuator to me
About $50 second hand
Old 04-01-2007, 06:17 PM   #10
Mechan1k
Mechan1k's Avatar
I bought a new one ... cos i didn't want to risk getting a 2nd hand part ... and have it fail on me again.
Old 05-01-2007, 10:40 AM   #11
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
cos we all know how good ford new parts are, they never fail!
just kidding, i would have done the same.
Old 05-01-2007, 05:01 PM   #12
TwistedEL
TwistedEL's Avatar
I went second hand when one of mine failed
Luck of the draw, this one is fine
Old 05-01-2007, 05:46 PM   #13
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Just Reset the Remote , did it to me and Fixed itself
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 11:08 AM   #14
kenz
BOSS Pilot
kenz's Avatar
Ok well I pulled both the doors apart to have another look cause I had to fix the handle anyways. With the cental locking I discovered that it still works. It will lock and unlock no worries but then if I try it again straight away it doesnt work. So I left it for a few minutes and it worked again first go but then it wont work properly again until I leave it a while and it works again....
Black BAII XR8 Ute
