Old 23-12-2006, 11:09 AM   #1
loxxr6
XB in parts...
loxxr6's Avatar
Default Window Glass
How much of an effort is it to get glass back in it's track ?
One of my windows has slipped off the track and I'm wondering if this is something that's relatively easy to fix ?
What tools do I need ? (I don't have electric windows)
Old 23-12-2006, 12:32 PM   #2
au2sw
Blown 5L coming
au2sw's Avatar
theres not to much effort involved, as long as just slipping off the tracks is the only problem. what has caused it to slip from the track? you should only need a phillips head ( + ) screw driver to undo the door card door handle etc. then it can be as simple as lifting the window back onto the track, making sure it stays inside the guides up the door
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2006, 12:45 PM   #3
TwistedEL
TwistedEL's Avatar
Phillips head and 10mm socket and maybe an extension bar
But something must have caused it to come off the track in the first place, you might need to look into that while you are in there
Old 25-12-2006, 11:56 PM   #4
loxxr6
XB in parts...
loxxr6's Avatar
Thanks guys.
A philips head was all that was needed. The glass had just come off the track (two yellow bits at bottom of the door). I think it may also not have been sliding up the inside "rail" as it gets winded up and down. It wasn't too difficult at all to fix.
