Old 29-11-2006, 05:20 AM   #1
Stav
Smile
Stav's Avatar
Default Dyno charts but whats been done?
What do you guys think has been done to get the gains on my car in the dyno sheets? Cam? Head? Have a few guesess and I will reveal soon.Bear in mind the power curve.
Old 29-11-2006, 08:04 AM   #2
JC
JC's Avatar
V8 transplant
Ford Performance Club ACT
Old 29-11-2006, 08:10 AM   #3
duaned
duaned's Avatar
a reduction in intake temp.
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 08:40 AM   #4
howesy
howesy's Avatar
What do the normal get in the sixes?
i would think around 120 which would make me think an exhaust filter and cold air could get this if done right.
But I'm only guessing, haven't seen the sixes dyno sheets
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 08:42 AM   #5
bodes-sh
did you end up getting the head ported? or did you get it tuned better?
Old 29-11-2006, 08:42 AM   #6
jonbays
TL40 Wagon?
Different days on the same Dyno.
Its colder in July so it goes better.
Also have a look at the BP the air pressure. Has anyone ever noticed that at Croydens it NEVER changes from 101.3?
I must run there for a big dyno post.
Last time I did I got 142RWKW by the way and a stocker with extractors got 123rwkw.
Old 29-11-2006, 08:47 AM   #7
Mechan1k
Mechan1k's Avatar
Have heard the same about CRD's dyno as well.
Also when you hear thier "Fully Sick" ad on the radio it doesn't inspire much confidence in them.
I was going to say an ECU reset ... just for fun though.
But also by the looks of it ... intake air temp would be the major cause though.
Old 29-11-2006, 08:49 AM   #8
Mechan1k
Mechan1k's Avatar
Also ... the dyno runs were run in different gears too.
Old 29-11-2006, 09:02 AM   #9
cArSiK
Plugs and or 100 octane fuel.
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 09:18 AM   #10
MRJUCY
Fordless
MRJUCY's Avatar
Changed down a gear.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 09:35 AM   #11
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Well, your running a taller diff... as peak power is coming out at just less then 160kph, whereas normal power would be around 170-175 ish....
By the looks of your a/f ratio, you have had an edit/tune... maybe....
other then that... just the norm suggestions...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 10:17 AM   #12
Casper
Contributing Member
Casper's Avatar
Dyno numbers (especially only 4kw difference on different days) effectively means nothing to be honest. Theres lots of cars claiming all sorts of numbers.. none of which is compariable with any other cars.. or with the same car on different days.
What was the difference between the dyno runs? You probably held your tongue on the other side of your mouth during the second run and wore boxers instead of breifs.
Older, wiser, poorer.
Old 29-11-2006, 12:53 PM   #13
jonbays
TL40 Wagon?
Well spotted Useless runs a 3.73 diff so thats third gear both runs in third.
Old 29-11-2006, 12:57 PM   #14
Sapper
Back to the AU
Sapper's Avatar
Have a closer look at the 2nd dyno chart. The bottom curve is torque, not AFR.
Its a bit hard to tell what might have changed as the second graph looks a bit 'chopped up.'
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU
2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth
Sapper is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 12:57 PM   #15
Mechan1k
Mechan1k's Avatar
Although one sheet does mention it was run in 4th (which i find hard in an auto to hold 4th on a dyno).
Old 29-11-2006, 01:47 PM   #16
xr8ute
Back on the road
xr8ute's Avatar
that graph on the right shows significantly fatter curve. Lots more power at lower rpm.
I'm with JC on this....Stav's just slipped a V8 into the wagon ;)
Old 29-11-2006, 01:55 PM   #17
james22
With da Warlords
james22's Avatar
ok useless, what dya done now.... refrigerated airbox lol.... no seriously i wanna know.... give me power
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 29-11-2006, 04:49 PM   #18
The Monty
Just slidin'
The Monty's Avatar
A hi-clone and a Brock polariser.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 29-11-2006, 05:23 PM   #19
poolkeeper
Its Resonating!
poolkeeper's Avatar
You changed the tickord snorkel to a xr6 turbo one, lol...
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 05:39 PM   #20
EFFalcon
Last warning
EFFalcon's Avatar
ebay 10HP gain chip/resistor
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 29-11-2006, 05:43 PM   #21
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Electric supercharger...
Carless
Old 29-11-2006, 06:10 PM   #22
HLC
Audi S3
vortex intake...
Old 29-11-2006, 06:13 PM   #23
Casper
Contributing Member
Casper's Avatar
10psi extra in the rear wheels
Old 29-11-2006, 06:24 PM   #24
FS5
nah man ,i know what you did .you put a tickford badge on it didn't you.
seriously what did ya do .you change fuel ,plugs ,leads ?or have the dyno's been telling porkies.
waiting in suspense
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 06:28 PM   #25
The Monty
Just slidin'
The Monty's Avatar
I am waiting..........
Old 29-11-2006, 06:37 PM   #26
bodes-sh
lol, i'd say 10psi extra into the engine...but you'd really hope to get a better power increase than that for 10psi
Old 29-11-2006, 07:42 PM   #27
Stav
Smile
Stav's Avatar
Sheez guys..alot of posts here today.
The car has edit tune in both charts.The lower run was done by one tuner and the car ran a 15.19 1/4 mile .The second tune was done at Croydons and got me a 14.7 and a fatter power curve. Two tunes two places and totally different results.All mechanical components were left alone but for just an intake.
Old 29-11-2006, 07:54 PM   #28
The Monty
Just slidin'
The Monty's Avatar
So, SFA difference in power, just a meatier curve, and youve dropped .49 off the 1/4? thats awesome. Good stuff.
Old 29-11-2006, 07:59 PM   #29
Doogstar
B-Series Moderator
Doogstar's Avatar
Goes to show how much dyno figures mean and what a good tune is worth.
BF MKII XR6 Turbo 2007 (Flare) ZF Auto
380rwkw - 11.68 @ 120.94mph 60ft=1.97
Custom Tune, Exhaust. injectors.1.2K Plazmaman 1.2K Plenum kit
Now with bigger turbo and 426rwkw.
Doogstar is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 08:01 PM   #30
jonbays
TL40 Wagon?
Well you can see where the first tune started to turn too rich in the top end which hurt the power a bit. the second tune doesnt have A/F ratio so we don't know the big diff is all A/F but it looks like it
