Old 27-11-2006, 07:38 PM   #1
SAM08U
Default Can you adjust EDIS ignition timing with EEC-V
Can anyone tell me if you can adjust the position of the unit that replaces the dizzy on the electronic models.
Mine seems to have a locking tab in the hold down plate that doesn't allow it to be turned when tightened. Also "Caution-Not adjustable" is written on the top of it.
The timing is out by about 40 to 50 degrees when checked with a timing light and the two pins earthed.
It seems to right ok, just misses and farts when its cold.
Is there another way of adjusting the timing on these models as i have heard that you can and can't.
Any help would be great, Thanx!
SAM08U is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2006, 07:46 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
i'm fairly sure the EF only uses the crank angle sensor on the front of the engine, sure the balancer hasnt slipped?
if the timing was out by that much, i very much doubt it'd run.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 27-11-2006, 07:48 PM   #3
SAM08U
That was rough guess buts it definately more than 20 - 30 degrees.
So it can be adjusted.
Old 27-11-2006, 07:49 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
nope, non adjustable.
i don't even know if adjusting it would do anything to the timing.
Old 27-11-2006, 10:56 PM   #5
Rmyers
Does Steve have a car?
Rmyers's Avatar
I agree with EFfalcon in that your balancer has probably slipped...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
