Old 20-11-2006, 02:06 PM   #1
snozzau
Default Rough Idle
Guys,
I have a very annoying problem with the idle on my XR6.
Sometimes it will idle as smooth as silk where other times it seems to rev up and
die down.
I have changed plugs & leads ,cleaned the injectors,changed the air filter,cleaned the throttle body and IAC.
Had a look at the fuel filter but it looks new.
After reading private9 post about oxygen sensors I will probably change that too but I dont think that will help my idle problems.
Ideas ???????
Scott
snozzau is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 08:20 PM   #2
Baboon_AU
Baboon_AU's Avatar
could try the throttle postion sensor
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 09:11 PM   #3
snozzau
Whereabouts is it and any idea how much to replace?
Scott
Old 20-11-2006, 09:43 PM   #4
bodes-sh
looking at the car from the front, it sits on the side i guess of the throttle body, about 90 degrees around from the ISC valve, looking from the front, it's on the front i guess you could say...it's a black unit with a wire hanging out of it...no idea on price tho, sorry
Old 20-11-2006, 11:06 PM   #5
wesomc
wesomc's Avatar
could check for air leaks...inlet manifold gasket, etc. use some aerosol (carby cleaner is good) and spray around the gasket and see if this alters the idle
wesomc is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2006, 09:07 PM   #6
Baboon_AU
Baboon_AU's Avatar
carby cleaner is expesnive... just mix soap and water and use a sponge to sponge it on and if it bubbles then you know u have an air leak
Old 21-11-2006, 09:47 PM   #7
wesomc
wesomc's Avatar
won't bubble, it sucks in air and leans out, but i suppose it wouldn't run well on soapy water either lol! carby cleaner is cheap when work pays for it...
Old 21-11-2006, 10:56 PM   #8
GK
Walking with God
GK's Avatar
You need a can for ISC cleaning anyway! LOL! Try that with soap and water!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 22-11-2006, 07:55 PM   #9
Baboon_AU
Baboon_AU's Avatar
sorry guys, i just read air leak and didn't think that it would be sucking air in...stupid me
