Old 11-11-2006, 11:45 PM   #1
mazza69
Default need some help
does any one know what power a 1997 nl fairlane 5.0 should have
mazza69 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 11:52 PM   #2
Allen
You win again, gravity!!!
Allen's Avatar
165KW at the flywheel is the factory rating for all normal 5.0's between EB and early EL.
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 11:57 PM   #3
Kryton
Kryton's Avatar
and 175 fwkw for AU Fairlanes. (not that its relevant).
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 11:59 PM   #4
mazza69
do you know what that is at the wheels becaus i put mine on the dyno and i got 137rwk but my air fule ratio was really high
Old 12-11-2006, 12:01 AM   #5
Kryton
Kryton's Avatar
lose about 25% from the fly wheel and you should get a ball park figure at the rear wheels.
137rwkw sounds about right if not better than average.
Old 12-11-2006, 12:05 AM   #6
Allen
Allen's Avatar
25% is accepted as the normal drivetrain loss, but there are heaps of other factors that can effect a dyno reading. Ambiant air temp/intake air temp, how hard the car is strapped down, auto or manual (being a fairlane im assuming it has an auto)
To me, 137kW sounds a little bit high assuming its a stock engine, esspecially if the AFR is high.
Old 12-11-2006, 12:07 AM   #7
phat_stak_tipa
phat_stak_tipa's Avatar
some dynos read higher too so yeah it really is only "ball park" some dynos may only show like 110rwkw....what mods you got done??? if your air/fuel is high??? which way like 10:1 or like 13:1
phat_stak_tipa is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 12:59 AM   #8
Steffo
LPG > You
Steffo's Avatar
165kW @ 4500rpm and 388Nm @ 3000rpm were the outputs of the NL Fairlane/DL LTD 5.0s.
Chassis dyno results should be taken for the grain of salt that they are, but 137rwkW is pretty normal for a proper, un-adjusted dyno run. Lots of (mainly Australian) dyno software seems to decrease the final result, and "increase" the drivetrain loss. Its just funny computer stuff that shouldn't happen, but whatever.
Basically, 300rwhp on an Aussie dyno = 320rwhp anywhere else.
Old 12-11-2006, 02:07 PM   #9
mazza69
just a full exhaust system with pacemaker headers and i was told that i might have a blocked fule filter a f@#*ed fule pump
Old 12-11-2006, 03:10 PM   #10
wodahs
wodahs's Avatar
recon ya should be happy if yar gettin 137 outa that
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
