Old 02-11-2006, 10:12 PM   #1
fairmont au
fairmont ghia au 2 wagon
Default wats an easy way to do plug leads
does anyone know an easy way of changing the plug leads in an au falcon?
fairmont au is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2006, 11:17 PM   #2
S3SR
S3SR's Avatar
buy one with them already on there......
or get them installed.....apparently on a hoist is easy i cant see how
all i did was remove the CAI upto the throttle body and stretch my arm under there and install each individually
good luck
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 12:43 AM   #3
blownba
LPG Forum Moderator
blownba's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all his assistance helping members with their LPG issues.
remove the bottom half of the airbox then you can reach your hand in easily to the coil.
blownba is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 12:55 AM   #4
s..ho
: thats the ticket
s..ho is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 01:08 AM   #5
TwistedEL
TwistedEL's Avatar
Yeap that is how it's done
I've said it before; hardest thing about it is if it's the first time being done you need to cut some cable ties.
After that it's nice and easy. Just do one at a time so you can't stuff it up
Old 03-11-2006, 01:30 AM   #6
5thFordWA
5thFordWA's Avatar
Are they like the EF with the 3-coil pack under the manifold?
I found the first time I tried to change just one lead it was very difficult. Next time I removed the air filter box and found it was easier to remove the coil pack screws and remove the coil pack with leads still attached out through the front. Then changed the leads off the car - easy - then tied long piece of string to each group of leads, passed the string through the gaps in the inlet manifold, and pulled all the leads through as I passed the coil pack back into position, then put the screws back in the coil pack. Much easier!
cheers.
1967 XR 289 V8 Falcon (1st) - 1973 XLE 250 4spd Cortina (2nd)
1987 XF GL 4.1 Dual-Fuel Falcon (3rd) - 1996 EF 4.0 GLI Falcon (4th)
2003 BA 4.0 LPG Falcon Wagon (5th)
2016 SZ Territory TX 4.0 Petrol (6th & last?)(Sadly, written off)
2004 WRX (Retirement Toy)
5thFordWA is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 09:34 AM   #7
TwistedEL
TwistedEL's Avatar
What are you 5ft nothing?
Because that's the only way it could be easier
Maybe your arms just aren't long enough
Old 03-11-2006, 09:55 AM   #8
phildee
phildee's Avatar
I got someone to feed them down to me while I was under the car, once you get your arm in teh right spot it was easy to do them 1 by 1
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 09:57 AM   #9
Mack 6
SUMP PLUG
Mack 6's Avatar
I agree, one by one and do it by feel instead of trying to look. I was able to get to them all by taking off the snorkel only, but I have kind of long arms.
Mack 6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 11:57 AM   #10
tick5.0
Want some classic?
tick5.0's Avatar
If you can get some one to help this way is very easy and quick. When I did a mates we pulled them out and cable tied them as factory and fed them down. Didn't take long at all.
Originally Posted by Walkinshaw
all i hear is wah wah wah a plastic car is quicker than my boat anchor
EF II XR8, Supercharged manual *** FOR SALE ***
XC Falcon, waiting for the Clevo & C4 - Sold
AE101 Corolla, the daily - Sold
SII RX-7, original - Sold
BF II GT
Alfa Romeo 156 JTS, the new daily
Z31 300ZX Turbo
tick5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 06:10 PM   #11
Baboon_AU
Baboon_AU's Avatar
i find the quickest and easiest way is to remove your snorkel and fan shroud and put your arm parralel to the rocker cover and under the plenum chamberand pull all the leads off. them feed one through one at a time.. the setup is like so:
34
25
16
should not take more than 10 minutes this way
good luck
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 06:27 PM   #12
stiddy
stiddy's Avatar
Takes about 10-15mins doing it the way FalconSR said to.
Old 03-11-2006, 09:40 PM   #13
EvilChief
Boost Addict
i normally remove the oil filter, makes life so much easier
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 20-11-2006, 11:27 PM   #14
Midnite
Midnite's Avatar
Any difference in plugleads for a standard INTECH in a AU2 and a TICKFORD VCT INTECH in a AU2 Fairmont Ghia ?
Midnite is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2006, 10:15 AM   #15
S3SR
S3SR's Avatar
according to BOSCH...plugs and leads suit each model (std AU inc XR6 VCT's so i assume that means the coil packs are the same and they take the same plugs)
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 21-11-2006, 12:51 PM   #16
janek
Ripping it up
yes
the vct uses different leads and plugs
janek is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2006, 09:22 AM   #17
Midnite
Midnite's Avatar
Unhappy
Originally Posted by janek
yes
I'm led to believe ( according to Ford ) that AU2s manufactured before 12/2000 used the same plugs and leads regardless of motor but AU2s manufactured after 12/2000 used different plugs for the VCT. My compliance plate says 11/2000 so may be borderline either way.
Old 28-11-2006, 09:05 PM   #18
rennie
BA Falcon, AUII. R.I.P.
rennie's Avatar
I just changed mine today, easy. get your car on ramps and have a mate feed n swap the new leads to you, while you plug them into the module. it looks a lot harder than it is.
AUII Forte: 18 Inch Tickford Wheels, Pioneer Head Unit, Kicker Speakers, Lowered, Tinted Windows.
R.I.P.
Current: 2004 BA Silk Falcon Futura
Mods:
Tinted Windows
Wheels: RJR 18" Tremors.
Sound: Soon: JVC DV7205 DVD Head Unit, Blaupunkt 480W RMS 4Ch Amp x 2, Polk Momo 6.5" Splits, Polk Momo 6"x9", Pheonix Gold 1500W Mono Block Amp, Earthquake SubZero Subwoofer
rennie is offline   Reply With Quote Multi-Quote with this Post
