Old 30-10-2006, 12:56 AM   #1
nikonxln
Default airbag light and error code
Hi all
great website - very informative.
Does anyone have error codes for the AU. When i turn the ignition on the airbag light comes on followed by 4 sets of beeps - the airbag light disappears on the third set?
anyone know what this means??
cheers
nikonxln is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 01:23 AM   #2
smally289
growing up is optional
smally289's Avatar
If the light goes out when the car is started, I'd say it was the DTE warning for the fuel level, less than 80km to empty?
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 01:26 AM   #3
nikonxln
ok well theirs just under a quater of a tank in it
im not use to this kind of thing just got this 99 au forte
had a shitbucket VL and ford corsair
Old 30-10-2006, 01:34 AM   #4
JC
JC's Avatar
Yep, if it's "beep, beep, beep" repeated 4 times, that's DTE.
Ford Performance Club ACT
Old 30-10-2006, 01:39 AM   #5
smally289
smally289's Avatar
What does the DTE display show on the dash? Its where the odometer is, you should be able to toggle between odo and DTE by pushing the odo reset button once
Old 30-10-2006, 08:35 AM   #6
JeffAU1
JeffAU1's Avatar
And incase you dont know DTE is Distance To Empty.
It will beep at you with 80kms to go, 40, and 20 I believe.
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 11:35 AM   #7
nikonxln
cheers guys very helpful
Old 30-10-2006, 11:16 PM   #8
Mechan1k
Mechan1k's Avatar
The DTE should flash in squence with KM left on start up with the beeping as well.
If it's a different tone beep ... it could be like what I had ... which was the handbrake warning chime coming on ... mind you my speedo was fluctuating between 10-20km/h in Park with the handbrake on ... hance the beeping as well. Weird ... it went away all by itself.
Old 31-10-2006, 10:22 PM   #9
HoT-AU
06 SS Thunder Ute
Somtimes my airbag light comes on from when i start it up and stays on for like 5-10mins while i drive! lol im guessing thats not good....
Ford..Holden.. Not fussed lol
HoT-AU is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2006, 10:25 PM   #10
Mechan1k
Mechan1k's Avatar
When turning the car on ... does it flash .... and then stay on????
If so that's an airbag code.
It will flash once ... stay off ... then flash several times (usually another 7 or 8 times).
Then repeat this 3 times.
I found the little cable loose under the driver's seat and clicked it back in ... this stopped mine
