Old 06-10-2006, 08:29 PM   #1
stiddy
stiddy's Avatar
Default Help.. maybe..
hey all..
M car has been running a little bit rough lately.. actually very rough.. What i thought was a bad batch of fuel is starting to prove very costly.
It wont rev past about 4500 and if it does it coughs and backfires and carries on.. sometimes even makes a popping noise out the airbox.....
if i suddenly step on it, it will cough, drop power for about a second then pick up, rev out to about 4000rpm and cough and splutter and miss and carry on again.. no happy with it. Sometimes it will do it all through the rev range and sometimes it wont do it at all and wont miss a beat.
Ive changed the spark plugs $133, plug leads $190, fuel filter $15, injector cleaner $20 and alot of time cleaning the fuel system.
Ive come to the conclusion that its the coil packs.. when they get hot, or something they start to play up..
SO can anyone tell me where can i get some aftermarket high-performance coil packs and price that will bolt into the stock location?? :
Thanks,
stidds
Old 06-10-2006, 09:17 PM   #2
Orbit
Resident Nyctophobic!!
Orbit's Avatar
no idea on the coil pacs. sorry.
how are you coolant levels?
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2006, 09:22 PM   #3
Ruger
Bseries Moderator
Ruger's Avatar
msd coils arent cheap expect 100-150 each
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2006, 09:55 PM   #4
hilly1981
Maybe one of the injectors is on its way out. Had a similiar problem and it was found the bad batch of fuel that went through caused damage to the injectors themselves.
Had them replaced with a set of reconditioned ones and the car was running smooth again as it should.
However you could be right about the coil pack as well.
Is there much difference when it is running cold and hot?
1998 AU Falcon Forte (Galaxy Blue, Sedan, 2.5" Lukey cat-back sports exhaust - single muffler, 17" ROH Wheels, 235/45/17 tyres, Low Suspension, Rear Spoiler, XR6T Intake Snorkel, K&N Panel Filter)
hilly1981 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2006, 10:32 PM   #5
HLC
Audi S3
sounds like my nitro rc car when its running rich. but that doesnt help :(
Old 06-10-2006, 10:35 PM   #6
bodes-sh
it also seems that it could be ecu problems, backfiring and coughing can also be caused by a timing problem, or possibly pinging? have you looked into the fuel pump, filter and strainer themselves? otherwise the ecu could be timing wrong...also check the camshaft sprocket, have you done anything to the cam or head lately?
Old 06-10-2006, 10:45 PM   #7
private9
www.TUFFCARPARTS.com
private9's Avatar
Sounds very much like either a VERY blocked fuel filter (replace this first as it's cheap) or a screwed fuel pump. I have both of these happen on a few cars and the symptons you're describing are exactly what I experienced.
Old 06-10-2006, 11:02 PM   #8
JC
JC's Avatar
That would be my guess too.
Ford Performance Club ACT
Old 07-10-2006, 09:23 AM   #9
xr8ute
Back on the road
xr8ute's Avatar
I third the blocked fuel filter idea too. Its also the cheapest thing to change next ;)
Does it run normal up to ~4000rpm, before it starts to cough and splutter?
Does it still brake down at 4000rpm if you are only at part throttle (vs WOT), or does it rev a bit higher before braking down?
Old 07-10-2006, 09:28 AM   #10
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Since you have changed the fuel filter i would look at the fuel pump, my missus ef I6 did the same thing, it would be fine from cold to hot but after about 20mins it would cough and chug, until one day it finally gave up all together and had to tow it. Anyways when the car is idling i would pop the boot and lift the carpet where the pump is and lightly give it a tap or thump it and see if it affects it in someways or maybe clean the connections it may help it may not but its better then just wasting money buying a new pump and its not really the problem. But my thought is the fuel pump and if not pump then i would suspect the coilpack, they are known for this.
Shaun.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2006, 03:43 PM   #11
stiddy
stiddy's Avatar
If i ease into it while reving it out, it wont miss or carry on all the way to redline, but foot to the floor it carries on..
stock cam, and i reset the ecu.. no difference..
Ive done the filter, and its still doing it..
the car runs fine while its warming up, when its hot or at normal operating temperature it stuffs around..
As for the coolant, when i checked just before its low.. will that effect anything ?
Im fairly sure its not the fuel pump..
Last night i took it for a very spirited drive, and it didnt play up once.. driving it today it was terrible.. maybe the cold night vs hot day makes a huge difference to the way the car behaves, but its never been this bad on a hot day.
Old 07-10-2006, 04:36 PM   #12
Futura01
horsepower
mate , i place a pretty big bet on your coil pack!!!
Same thing happened to me was driving my car like normal for most the day and didnt miss a beat then i parked it to go shopping come back .
started okay then 5mins later started spluttering and coughing then just died!!!!
It was the coil pack!! best way to check it check the spark from each lead
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2006, 05:06 PM   #13
jonbays
TL40 Wagon?
I would say coilpack too. I have a good spare somewhere in the garage. pm me and you can try it first rather than just buy one. bastard to fit though.
Old 08-10-2006, 02:48 PM   #14
Baboon_AU
Baboon_AU's Avatar
you would have to fit it from the bottom with a help of a mate from the top. then snorkel and fan shroud will have to come off to for your mate to help.. unless you want to take off the plenum chamber...
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2006, 04:23 PM   #15
Orbit
Orbit's Avatar
if you've noticed the coolant having dipped "recently" without any signs of leak. It could point to something internal.
But my money is on the fuel pump an dif its not that then the coils.
and if not that then i'd be looking internal.... :
atleast a new engine isn't that expensive... :
Old 08-10-2006, 07:20 PM   #16
StookEB
With my little experience i'd say it's the coil, well at least you can fix all parts so they won't brake while on the 1/4.
Now driving an unbreakable Hilux, which is becoming full of rust :
StookEB is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 12:54 PM   #17
Mechan1k
Mechan1k's Avatar
Stiddy ... how did it go.
To me it sounds like a coilpack ... had similar issues with the ute.
Not too hard to change ... picked up a literally brand new one from Macarthur Parts Plus for about $40 .... Ford wanted nearly $300 for one .... meh.
Old 11-10-2006, 02:01 PM   #18
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
I would almost bet my left nut on blocked cat. It is exactly what mine did. Wouldnt rev past 4500rpm, then over tmie that dropped lower and lower, if you ease it on it will but not if you flatten it or give it a bit it woul dcough and fart. the reason being is that the ECU is cutting fuel off (which gives a fuel starve indication) because there is to much back pressure, get your cat looked at. I took mine in to a well known mechanic to diagnose and they had the car for 2 days, spent something like 15 hours on it and then finally came up with blocked cat.
From what you have described its identical to mine
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 07:33 PM   #19
stiddy
stiddy's Avatar
OK very very strange **** going on lol..
washed my car tonight, and while I was at it I topped up my washer fluid with the hose.. and thought hmmm engines a little dirty i'll hose it down..
so full pressure from the hose all over the engine bay...
started the car, it idled rough, coughed and spluttered like it does and then ran fine..
took it for a brap up the street to 'dry' the engine...
No missing, no backfiring, no poping no nothing!!
What the hell??, took it for a long drive, didnt miss abeat once.. and to top it off it feels like its going better now than what it did before it started all the stuff around..
What makes me say this?? I just recently got new tyres and I struggled to spin them, 4000rpm dump and its away with a little chirp... tonight, 4000rpm dump and all I get is a review mirror full of smoke.. even taking off then standing on it, it would break out all through first and hold half of 2nd..
drive it hard or soft, wide open throttle or easing into it, gave the car hell for about 20mins and drove it grampa like for 20mins.. didnt miss a beat once..
Anyone explain this..
Old 11-10-2006, 07:40 PM   #20
bodes-sh
sounds very much like a coil pack or lead issue, i guess i should have asked this at first, were all your plug leads plugged right in both on the plugs and coil pack? im thinking the water may have knocked it and made it sit more on something
Old 11-10-2006, 08:48 PM   #21
xr8ute
Back on the road
xr8ute's Avatar
I think it means its time to take it back to the track for a PB ;)
Old 12-10-2006, 06:49 AM   #22
Mechan1k
Mechan1k's Avatar
Gremlins can be nasty little buggers.
Old 12-10-2006, 09:18 AM   #23
I6corp
Was V6corp
I6corp's Avatar
One of the sensor's were loose, or dirty and the pressure wash fixed it?
Car: 99 AU I Forte Sedan
Colour: Blue
Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust
Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash
Bling Mods: Tinted Windows; JVC CD/DVD HU
Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags
I6corp is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 09:24 AM   #24
nat_daly
Nat D
nat_daly's Avatar
i second that
old ride#1: ED XR6 5 speed-gone to new home:(
old ride#2:dumped EL fairmont 5l
new ride: Winter white AU2 XR8-manual
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 09:27 AM   #25
Mechan1k
Mechan1k's Avatar
Dodgy oxygen sensor maybe.
Old 12-10-2006, 04:11 PM   #26
Stav
Smile
Stav's Avatar
Stidds ..try red bull instead of water next time.
Seirously though that is wierd.My first thoughts were that you have a leaking intake manifold gasket.The other thought is a bad electrical connection somewhere..
Old 12-10-2006, 04:13 PM   #27
Mechan1k
Mechan1k's Avatar
errr ... i'd hate to change an intake manifold gasket ... not fun.
Could be a dodgy earth.
could be a number of things ... I guess it comes down to trial and error in some cases.
start with the cheapest items to replace and slowly work your way up until it is fixed.
Or ... you might have fixed it with an engine bath
Old 12-10-2006, 10:08 PM   #28
stiddy
stiddy's Avatar
Its stuffed again..
Was running well all day, on the way home from work this arvo sitting in traffic doing about 30km/h in 2nd, the car just went all spastic, didnt idle right, coughed spluttered carried on backfiring again.. then tonight its fine for a bit, stuffed for a bit, fine for a bit, stuffed for a bit..
Ready to roll and burn the thing!!
Im going to flush the fuel tank, fuel lines, fuel rail, new filters and injector clean this weekend.. and i'll check the coils. Hopefully this fixes it.
Old 13-10-2006, 10:22 AM   #29
poolkeeper
Its Resonating!
poolkeeper's Avatar
Havent you already done that stiddy?
My mate had a problem like yours, one of the ecu wires had come loose.
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2006, 10:38 AM   #30
Mechan1k
Mechan1k's Avatar
It's weird that it is doing it sometimes and not others.
It might be a dodgy earth connection somewhere.
Weird thing happened to the brother-in-law's VR ... kept cutting out ... and in a dip in the road near home it lost all power and conked out. Needed the earth connection cleaned up ... got another one put in place as well ... just to make sure he had a good connection.
Actually .... might look at getting a separate earth done on the ute actually.
