Old 27-09-2006, 09:28 AM   #1
amiers
Default strange clicking?
car is a AU2 FAIRLANE 5L, when i touch the acc pedal i get a clicking sound its just as i push down and when the pedal is coming off. the click is coming from the left of the dash, under, it seems to be where the bem is. any ideas what would be causing it?
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 12:26 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Maybe the Flux-Capacitor is damaged : .. hehehe
:eclipsee_
Old 27-09-2006, 01:22 PM   #3
bodes-sh
sounds like what others have described as the charcoal cannister...which is in the left hand side wheel well
Old 27-09-2006, 03:30 PM   #4
clontarf_x
Charcoal canister is under the LHF guard, not in the car. If it was in the car that would make driving fun on a whole new level
Manual? I have no idea what Fairlanes are. If it is manual it could be the common pedalbox issues (firewall becomes cracked/damaged).
Otherwise, just check for cables that could be becoming loose. Is it only while the car is running or when it is off and stationary?
- Shane
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 05:29 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
can you buy manual fairlanes?
Old 27-09-2006, 05:31 PM   #6
Casper
Contributing Member
Casper's Avatar
no...
Older, wiser, poorer.
Old 27-09-2006, 05:38 PM   #7
amiers
wrong track guys. when i push the pedal there is an electrical click. not something broken click. its coming from inside the bem i think. i can put my hand on it and feel it click inside. the car is also on gas if that helps.
Old 27-09-2006, 05:47 PM   #8
XR6-VCT-2000
Fantastic Plastic
I dunno where they mount the solenoid for the gas these days ( still under the hood ) ? , if it aint under the hood then it could be mounted somehwere around there , and causing the clicking sound .
:eclipsee_
Old 27-09-2006, 08:41 PM   #9
TwistedEL
TwistedEL's Avatar
Does it do it key on engine off or just key on engine on?
Old 27-09-2006, 10:56 PM   #10
amiers
does it when key on, gas and petrol. motor on/ off
Old 27-09-2006, 11:15 PM   #11
TwistedEL
TwistedEL's Avatar
It's a wierd one, does it sound like a relay - i.e like your indicators
And does it do it once, or cycles, if so how long and how fast?
Old 28-09-2006, 11:19 AM   #12
amiers
the click is coming from the bem as far as i can see. it does it just as the acc is pushed down and at the same point on the release. its about 3mm so it is something coming in/on when i touch the load pedal.
Old 28-09-2006, 04:07 PM   #13
fomoco3628
fomoco3628's Avatar
i have a click in my car... when i slow down at corners it sometimes click..i think it is when it changes down (it's a auto) should i be worried about it?
fomoco3628 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2006, 01:26 PM   #14
GleeV8wgn
GleeV8wgn's Avatar
i recently had my wagon converted to LPG. My Lpg regulator sits on the right hand side of vehicle. When i pressed accelerator pedal i had a noticible clicking sound. I noticed that the hole for the new LPG wiring in the engine bay to the cabin was open or unsealed. I just sealed it with silicone and the clicking cannot now be heard. My issue was that you could hear the regulator pumping through the unsealed hole when pressing the accelerator.
GleeV8wgn is offline   Reply With Quote Multi-Quote with this Post
