Old 25-09-2006, 06:56 PM   #1
slickef
Apprentice Fridgey
slickef's Avatar
Location: In a lil place called Gladstone aka. Glad2bstoned
Default 351 into an EB conversion?
has anyone put a 351 into a EB??? is this conversion easy or is there a lot of work to it? i have a 93 eb station wagon that my dad wants to convert into a drag car, i am able to pick up a running 351 and gear box for $1000, can anyone help?
96 EF Falcon Futura, Powered by Microtech, 2222549 Crow Cam, Metal Gasket, Port and Polish, Oversized Forged Valves, EF Fairmont Dash, K&N Highflow Filter, Pacemaker Competition Extractors, 2 1/2 Mandrel Bent Exhaust, High Flow Cat, Converter Shop 3500 stall, Shift Kit, 4.11 Diff Ratio, Mini Spool
Best ET 14.654 @ 88.270Mph at Benaraby Raceway, Gladstone Queensland
slickef is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2006, 07:08 PM   #2
EBFalcs
is the wagon a six or eight at the moment
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2006, 07:09 PM   #3
slickef
Apprentice Fridgey
slickef's Avatar
good ole six
Old 25-09-2006, 07:12 PM   #4
LUXO_8
windsor user
i'd send a pm to racecraft and eav8.... they've both done 351 into ea conversions, and should be able to help you out
Old 25-09-2006, 07:12 PM   #5
EBFalcs
it will be a bit harder then. but i got a street fords mag with a 351 EB XR8 in it, and because the 302 is the same block and all that as the 351 it slots straight in with all manifolds, (i'm pretty sure that's what the article said) so if you get an XR8 loom and computer it should all be sweet. even easier if you carby the motor
Old 25-09-2006, 07:16 PM   #6
LUXO_8
windsor user
ebfalcs.....the 302 from an EB is a windsor.
it is not the same block as a 302 or 351 cleveland
it is exactly the same deal to convert a 6 cyl or V8 eb to clevo
Old 25-09-2006, 07:18 PM   #7
slickef
Apprentice Fridgey
slickef's Avatar
its a 351 clevo carby fed, will be ripping all electrics out of it as nothing but light and ignition will be needed
Old 25-09-2006, 07:30 PM   #8
Jason[98.EL]
Jason[98.EL]'s Avatar
1 question is it going to be used on the road
if so you wont be able to use a carby if not go for it
jason
[SIGPIC][/SIGPIC]
Old 25-09-2006, 08:34 PM   #9
slickef
Apprentice Fridgey
slickef's Avatar
it will be strictly for strip use
Old 25-09-2006, 08:43 PM   #10
Jason[98.EL]
do it then if its only going to be used on the strip you can do what ya want without the road legals coming into play
1 thing though is if it gets into a certain time bracket on the strip you need to comply with a few racing specs
there are a few good sites to look at but im not sure of the exact site addys but i will look them up for you if you want but im sure that if you did a search for drag racing in australia you will find all the info you require
hope this helps
jason
[SIGPIC][/SIGPIC]
Old 25-09-2006, 09:19 PM   #11
slickef
Apprentice Fridgey
slickef's Avatar
i race my ef now, so yeah i know all the mods that need to be done and all the restrictions on times
Old 26-09-2006, 03:11 PM   #12
castek
keep us updated, sounds like a good idea. i was gonna do something similar. i was going to buy a injected 5litre windsor and through 351 internals.
castek is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2006, 06:37 PM   #13
mcflux
mcflux's Avatar
1tufel, you can't do that. 302Ws will only take up to a 347ci stroke & bore. As for the rotating assembly, I'm unsure whether a 302C's rotating assembly is the same as a 302W or not.
Old 26-09-2006, 09:03 PM   #14
BLSTIC
Ghia5L, it wouldnt be. Bore and stroke may be the same, but isnt the windsor a 60 degree V? If it is, the crank pin 'timing' (for lack of a better word) would be different..
that said, i really, really want to see a 351W in an E-series. If a clevo can fit, surely a bigger windsor can.
cya
Ben
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2006, 10:48 PM   #15
LUXO_8
windsor user
the 351 windsor block is different to a 302 windsor block...the 351 has a taller deck height to allow for the extra stroke....
its true that the 302 windsor block will only go out to 347
Old 27-09-2006, 12:57 PM   #16
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Windsor is a 90deg Vee, not 60deg.
Clevelands and Windsors are a fair bit different internally, not many parts interchange between the 2, and really, why would you, when there's unlimited amount of Windsor parts available from the US.
Check this link then - http://www.fordforums.com.au/showthr...0&goto=newpost
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 05:20 PM   #17
Psycho Chicken
Psycho Chicken's Avatar
Exactly, why would you cripple a Clevo with Wheezer parts anyway?
