Old 09-09-2007, 12:53 AM   #1
reece1
reece1
reece1's Avatar
Default au no power issues
have a au that has a miss when you free rev it just off idle and when you drive it it has no power like retarded timing. have checked everything fuel pressure swaped lots of electronic from one au to another with no luck i am about to send pcm to be checked has anyone come accro0ss this ? any ideas much appreciated?? :
reece1 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 06:49 PM   #2
reece1
reece1
reece1's Avatar
cmon au fanatics
Old 11-09-2007, 07:03 PM   #3
The Monty
Just slidin'
The Monty's Avatar
Im stumped sorry man.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 11-09-2007, 07:23 PM   #4
Grechie
Grechie's Avatar
when your driving, and your coasting along, if you suddenly stomp the peddle to the floor, does it hesitate?
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:35 PM   #5
mik
mik's Avatar
has it been properly serviced ? fuel filter, air filter, plugs, leadsetc? on lp gas?
Old 13-09-2007, 07:07 PM   #6
reece1
reece1
reece1's Avatar
Default no its
it just doesny power along, its like a blocked fuel filter, i got pcm back today it tested fine so i will refit it tom orrow and look elsewhere, i think im going to try a cam position sensor has anyone had one of these fail :
Old 13-09-2007, 07:34 PM   #7
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
sounds like you cat converter could have collapsed blocking the exaust... mine did this in my XR8
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 08:02 PM   #8
stavros68
harmonic if its slightly stuffed it will make your car miss
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 08:03 PM   #9
FGII-XR6
FGII-XR6's Avatar
hook it up to a scan tool that will spit trouble codes out and steer you straight ford dealers and some mechanics have them
Old 13-09-2007, 08:57 PM   #10
xr6'n
i have the same issue, changed just bout everything including tps sensor, ive given up
xr6'n is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 09:46 PM   #11
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
drop the exaust of just after the cat and shine a torch up it... then start the car and give it a rev and see if bits of your cat come out with it.
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 13-09-2007, 11:49 PM   #12
sly
Sly like a G6
sly's Avatar
My cam pos sensor failed. It stuffed the injector pulses above 3000rpm and sounded/felt like a miss. Under 3000 it was as good as gold.
Do the basics first. Check your cat, plugs, leads, air & fuel filters. I found out only last month how much difference replacing a collapsed cat makes. As au3xr6 said, get a scan tool put on it to check for DTC's (diagnostic trouble codes). You should be able to get this done under $75.
Sleeper, anyone?
Old 14-09-2007, 09:26 AM   #13
odysseyesm
I dunno, it looks right..
I've got the same problem...
Just picked up a 2000 AU2 Fairmont Ghia (duel fuel) & VCT, it was serviced just b4 i picked it up but prob only oil+filter and it still feels pretty doughy. Put a new air filter and some injector cleaner in it last night but no difference yet. Cruise along and step on it and it misses & hesitates for a couple of seconds b4 picking up.
Did a hand timed 0-100 for a 11sec result...too slow for the car. Does have some sort of exhaust/extractors on it but unsure at the mo.
Don't know the history of the car but it looks like it's had a pretty easy life with 173k's.
I'll have a look at the cat etc over the weekend and report back.
odysseyesm is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 10:08 AM   #14
StealthAu
^^^^^^^ Replace the plugs and leads for starters
Old 14-09-2007, 11:57 PM   #15
SA-AUII-MAX
true blue
Howsit Reece
Have some problems with my own AUII at the moment, lots of pinging and so on, but after many tests started to replace electronic parts aswell. Started with the T-MAP sensor and although it did not give any error codes before, the result is very good. Suffered also from a slight miss above idle speed, but that’s gone. Throttle response is a lot better too. Idle is constant, but is still pinging under a light throttle now and then. After replacing the knock sensor, with no better result, the only thing that can be wrong now is somewhere in the wiring or the PMC. Going to take it apart this weekend.
I’m busy over 6 month with this now and getting also Pi**ed off with it. But do yourself a favour and check the wiring. Not just the connectors but also resistance or voltage. Fixed error codes that came up by just checking and fixing the wire loom.
SA-AUII-MAX is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2007, 12:20 AM   #16
ForteAU
i dont know
ForteAU's Avatar
I have also a power problem in my AUII, I take of from a dead stop and she doesnt go anywhere, have done all the basics, oil, oil filter, scan tool (no errors), plugs, leads, when cruising along at what ever speed and i put my boot into it it doesnt always change down gears and when it does it take a few seconds or a release then press on the throttle again, but with all that said once it gets upto about 3500 - 4000 rpm she goes hard......till the gear change then back to normal, i have checked the cat as much as i can, the car has done a little over 120,000 ks, i bought it when it had 107,000 on it, could it be the transmission? service on tranny help maybe?
thanks in advance Shane
ForteAU is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2007, 12:28 AM   #17
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
Hey Shane.
My mate had this with his Ser 1 Fairmont. His turned out to be the gearbox. Because his Mrs at the time was manual shifting down gears instead of brakes (like it was a manual). In the end it shattered 2nd gear. still drove and went hard down low but sometimes wouldnt change gears and sometimes it would. I cant remember but i think his came up with an error not 100% sure though
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 21-09-2007, 08:39 AM   #18
odysseyesm
Replaced the plugs and leads over the weekend but it hasn't really done much.
I noticed that the guy who had it before me (still a member on here I think?) had put some extractors and a pipe on the car. The only thing is that he's used silastic of some sort on the exhaust manifold.
Silastic (Anything with silicon in it) and Oxygen Sensors don't go together, so that's my next port of call.
Also spoke to the guys at KPM about the whole edit thing to fix the power/ poor economy thing and they'll have a look at it on Monday just after I get the cat etc looked at by the guys at Exhaust Technology right next door.
Old 26-09-2007, 02:19 PM   #19
odysseyesm
Had the exhaust looked at the other day. Turns out that there was only a 2" system from the standard cat and a set of extractors (Unknown brand).
The cat was ok but not brilliant and the muffler (std) was starting to break up a bit.
A new hi-flow (MetalCat) 2.5" Cat was fitted along with a Redback 2.5 system. There was an immediate improvement in the throttle response along with an increase in fuel economy.
From 21lt/100k to 17lt/100k, not great figures but the guy who had it before me used gas too much without switching over to petrol to clean things up a bit.
The exhaust guys seem to think that the silastic issue isn't that big of a deal, but I'm still not 100% convinced. As the car has a "Sapphire Blue" warranty of 3yrs and unlimited k's I wont replace the oxy sensor out of my own pocket. I'll drive around for another 2 more tanks of petrol and see if that fixes the power/economy issues, if there's no improvement I'll be taking it in to get the oxy sensor and TMAP looked at.
Rgs.
Old 29-09-2007, 05:57 PM   #20
ford-88
ford-88
my ute au3 was doing the same use to cut power to the engine when you stomped the gas (like a speed limiter) done it iderling an crusing had a scan and fuel system checked that was all good than swap the T_MAP TPS and IAC an put in another wiring loom that fixed the problem
ford-88 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2007, 11:49 PM   #21
sly
Sly like a G6
sly's Avatar
Was that a dashboard or engine loom? How long did it take to do? If engine loom it looks the sort of job that's easier with the engine out...
Sleeper, anyone?
Old 30-09-2007, 04:20 PM   #22
ford-88
ford-88
engine loom took bout 2 hours to take off the old engine an transfer across. you have to take the injectors an rail out to take the T_MAP out.
Old 21-11-2007, 01:37 PM   #23
odysseyesm
Default AU No power Issues
Just as an exercise thru reading posts on FordForums, I reset/re-calibrated the ECU using the Battery disconnect method on the weekend.
I was sceptical but it has definately improved things so far...
The fuel economy is up (Was 24lt/100klm Is Now 15.5lt/100klm and falling).
The seat-of-the-pants power meter is also very happy with the increased power.
This only using petrol as I haven't tried it on LPG yet, although I do expect a similar improvement on both fronts.
I'll keep posting as I go...
Old 21-11-2007, 02:14 PM   #24
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
As JC Said to me when I was suffering this very same issue, "Fuel Pump, Fuel Pump, or Fuel Pump!
Old 21-11-2007, 04:16 PM   #25
FTe342
FTe342's Avatar
I cleaned the TPS and then did the battery reset and this fixed a stumble off idle problem
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2007, 06:35 PM   #26
FS5
read this thread may have something to do with it.
http://www.fordforums.com.au/showthr...hlight=pinging
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
