CRE.87V
hey all...car seems to be wandering around the road a bit...steers to one side when hitting bumps...wat could this be...just had wheels aligned
Hi
the same thing happen to me this week after i took mine for a wheel alinement .Took car back the adjustment on the lhs rear came loose or they forgot to tighten it.lhs rear tyre was crooked and scrapping on the road.They fix it all up now and everything is sweet.Every time i went over a bump on the road the car would go everywhere..Is the steering wheel centered.Check all the tyres are strigh and not pointing in or out. |
#3 | |||
That's Numberwang!!!
Has the problem just happened recently? Or has it been going on for sometime?...
One thing it may be is if you have put new tyres on it, the sidewalls could be too stiff. And when you hit a bump, instead of the energy being absorbed through the tyre, it hits the steering arms and steers you sideways...
www.aufalcon.com.au/only1 FAIRMONT GHIA: SO GOOD, THEY NAMED THEY NEW FALCON AFTER 'EM Quote:
CRE.87V
steering wheel is out a little....tyres have been on car for nearly a year...done only 20,000 kms
#5 | |||
If the steering wheel is out a little, did the shop who alligned the wheels check the camber?
My fairmont has the same problem, the camber on the front left is out in a negative way, so it means the steering wheel is pointing to the right a little to keep the car straight... Fixing it is on my to-do list... As for the bump-steering, there goes my tyre theory. Worn shockers maybe... If one shocker absorbs better than the other, it could cause your car to change direction.
alignment and if it tends to do it on bumbs maybe shocks
CRE.87V
hey all....changed the front struts and its not much better....if i push down the rear end it bounces 2wice then stops....could this be the rear struts too
Steve
yep they could be shot.
