Old 04-09-2007, 07:14 PM   #1
fernsantos
Default Auii Fairmont Ghia Boot Gas Struts
I have bought some Boot Gas Struts.Can someone please tell me if these are hard to put on and some how to do it help.
fernsantos is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 08:30 PM   #2
Chippar
The Ancient Warrior
Chippar's Avatar
Just use a flat blade screw driver to lever the clips out and remove the struts from the pivot ball.
When replacing them, pry the clip out just far enough to push the end over the ball, then push the clip back on fully to secure the joint.
A little bit of dry lubricant on the pivot ball is helpful when replacing the struts also.
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 11:14 AM   #3
fernsantos
Thanks for that replaced them today easy job.
