Old 04-09-2007, 01:35 PM   #1
FPVHO
V8 Muso
FPVHO's Avatar
Default AU Dash Cluster
Hey there guys.
New to forum but I reckon it's one of the best from what I have seen.
Here's my prob,
I have recently purchased an AUII futura and would like to swap the dash for an upper model to have access to an oil pressure switch, because as we all know te idiot light just doesn't cut it!.
Should I be lookingat Fairmont or XR6 also what wiring mods need to be done.
I can read wiring schematics and have done full engine bay rewires in the past for mates, but nevr attacked a dash.
If anyone out there can help it would be greatly appreciated.
Thanx guys
Troy
FPVHO is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 01:50 PM   #2
StealthAu
You want an XR cluster, if you use a fairmont/lane one you loose you're dte display. You also need to replace the oil pressure switch with an oil pressure sender. As far as wiring goes I'm not to sure about the wiring, I only have details for the series 1.
Old 04-09-2007, 03:12 PM   #3
james22
With da Warlords
james22's Avatar
And series II & III I believe work off the idiot light anyway. The gauge itself is there for show I think. It either sits on 5 out of 7, or 0. Thats it.
I'm sure someone else here can confirm??
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 04-09-2007, 04:04 PM   #4
StealthAu
As I have already stated, to make it function corectly you need to replace the pressure switch with a sender. They cost around $50 hence why Ford decide to scimp and use the $8 switch.
Old 04-09-2007, 04:10 PM   #5
DJM83
Barra Turbo > V8
DJM83's Avatar
Here is some info on it in the T series room
http://www.fordforums.com.au/showthread.php?t=96445
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 05:23 PM   #6
howesy
howesy's Avatar
Try this document and the linked images may help with wiring as well.
http://i137.photobucket.com/albums/q.../pinoutsI6.jpg
http://i137.photobucket.com/albums/q.../pinoutsV8.jpg
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 06:32 PM   #7
FGII-XR6
FGII-XR6's Avatar
you can't just put a sender in and the gague will work this is just a dummy gague I've been right into it with an instrument tech and there is no easy way to make the gague a proper gague in the S2/3 cluster
Old 04-09-2007, 06:37 PM   #8
b2tf
not here much anymore
b2tf's Avatar
Yes the gauge is a dodgy one. No it cant be "fixed" by using another cluster etc. By far the easiest way is to just fit an aftermarket one, if you can handle having another gauge somewhere on your dash.
2024 F150 XLT
