Old 13-08-2006, 07:12 PM   #1
Whoosha
AU DIE HARD
Whoosha's Avatar
Default radiator hoses
just wondering if any one knows what sort of tool you would need to undo the top + bottom radiator hoses on a XR8 one end is your usual philiphs head screwy the other is a round headed thing : note; (small vise grips are your friend )
Originally Posted by Riksta
Old 13-08-2006, 07:15 PM   #2
Au2falcons
Winter all year round
I believe the round thing is a cap, pop it off & you can get to the phillips head.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 07:23 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
puff puff... runs back in from shed ... :thebirds: your belief is rite it is a cap go figure ..thanks for that .. next question... how can you get the gunk out of radiator header tank ... short of buying another :
Old 13-08-2006, 07:26 PM   #4
philstoj
philstoj's Avatar
Nope, thats the way they are, they have a tab on them, and when it gets tight it breaks off, its not a cap, thats what you need to turn to loosen the clamp.
Vise grip is your freind, or a set of cresent pliers. :
Old 13-08-2006, 07:29 PM   #5
Au2falcons
I just did a coolant change on my AU today, I removed the tank & blocked all the outlets, filled it with water and shook the crap out of it.
It got 80% of it off, according to the gregorys workshop manual you can use baking soda to clean out, just make sure you rinse it out properly.
Cheers,
Adrian.
Old 13-08-2006, 07:42 PM   #6
Baboon_AU
Baboon_AU's Avatar
i work on earthmoving machinery and we clean out radiators with omo and finish in the powder form.. you just mix it with the coolant, run it for a day and then drain it and its pretty clean. alot of on highway trucks do this too and its perfectly safe to do on cars aswell
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 08:07 PM   #7
bodes-sh
lol i guess it could also clean out the inside of your engine... :
Old 13-08-2006, 09:10 PM   #8
Baboon_AU
Baboon_AU's Avatar
umm....no??
Old 13-08-2006, 09:10 PM   #9
private9
www.TUFFCARPARTS.com
private9's Avatar
I used to remove the overflow tank (pretty easy only a few screws and pipes) fill it with water and a little gravel (yes rocks!)
Shake it for a while, and it will come up like new!! Just make sure you rinse the crap out of it and don't shake it too hard.
Old 13-08-2006, 10:09 PM   #10
ronwest
All Bran = Regular Member
I used the baking soda as suggested in the manual and it gets rid of 99% of the discolouration but not the scum that resides on the walls of the header tank.
For that I used sand (sand and water slurry)... shake it about for a while and rinse thoroughly.
Works very well.
Old 14-08-2006, 08:08 AM   #11
Mechan1k
Mechan1k's Avatar
I just bought a BA header tank ... fits perfectly ... LOL
Old 14-08-2006, 01:03 PM   #12
Whoosha
AU DIE HARD
Whoosha's Avatar
Thanks gang ..left it soaking over night in a sugar soap solution followed by baking soda & vineger.. got 80% of it out. priced a new one for $90 but mite go with the "BLING" alloy for a early christmas prezzy for me :
Old 14-08-2006, 06:30 PM   #13
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
once you clean it, paint it up to a matching colour to something and it will look great, just leave a little part on the side so you can see the level even tho you dont need it cause you have the coolant level sensor.
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
