Old 26-07-2006, 12:28 AM   #1
benXaGt
Default What do you reakon my car will do?
Just wondering what time you guys reakon my car would get at the drags.
Also roughf idea on hp at wheels?
Im getting it dynoed on sunday
Specs
Ford xa coupe
302 clevo
eldelbrock manifold
600 holley
msd
Revs to about 5500 dont no cam specs
Toploader box twin plate clutch
Nine inch diff 3.9 gears lsd
Dual 2.5 system
14 inch mags 265's on the back
245's on the front
benXaGt is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 08:07 AM   #2
brenx
brenx's Avatar
Roughly? 14.6->15.4. [edit]You'll probably run out of rpm with the 3.9 gears. A mate of mine ran out of rpm with 3.5's.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 10:13 AM   #3
82XD393.3v
82XD393.3v's Avatar
Its a relatively stock 302 in a heavy coupe maybe 120rwkw id say high 15 but this is only a guess based on what you have said as far as engine specs but you have good gearing so maybe a mid 15
XD with EL xr8 front 393 12.1 114mph on lpg: Sold
FG F6 Manual 366RWKW tuned by BLUE POWER
82XD393.3v is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 02:43 PM   #4
jd dad
My guess would be about mid 15`s, the low gears wont make that much difference with the stockish driveline
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 09:38 PM   #5
benXaGt
Cool thanks ill post my dyno results on sunday night.
Ive raced a XR8 el and that runs 15's (15.10) that was with my old set up (2.92 gears and really sick 302 needed a clean up and service) and i just beat it.
Im hoping mid 14's to high 14's.
Im saving now for my other engine to get built hopefully ill get it in in a few months time before motorvation.
Old 26-07-2006, 10:06 PM   #6
xdclevo
The Fun Mobile
xdclevo's Avatar
Are you going to run it over the 1/4?
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2006, 06:46 PM   #7
benXaGt
Yes but here in perth its too wet for the drags to be open so i have to wait til september or october i think.
Old 12-08-2006, 07:59 PM   #8
benXaGt
Ok i got it dynoed today 214.6 hp at the rears. Ill keep you all updated about the drag times
Old 12-08-2006, 08:33 PM   #9
brenx
brenx's Avatar
what kind of vacuum (hg) did it pull? Power sounds ok though.
Old 12-08-2006, 10:22 PM   #10
benXaGt
not to sure ill try and scan the results within the next few days.
Its pretty much a stock 302 with the little bit of work(manifold)
Old 20-08-2006, 11:23 PM   #11
benXaGt
Ok hears the dyno results..
The only thing is it dosent show the torque curve.
Old 22-08-2006, 07:43 PM   #12
PhantomXR8
Now a FG XR8 in Nitro
PhantomXR8's Avatar
Thumbs up 302
That doesn't appear to be a stocker, may have a good exhaust though. I'm tipping the car weighs around 1600kg. 214hp at the wheels is about 210kw at the engine. Do the maths, 1600kg divied by 210kw is 7.6 kw per kg. Let's look at a 220kw AU XR8, 1650kg divided by 220kw is 7.5, those great great cars were good for a 14.8 stock from memory. I'm thinking a 14 is acheivable, put a 5 speed in it, drop your diff ratio to somewhere around 3.9 and slap on stickier tyes you'll get it.
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs
PhantomXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 09:38 AM   #13
82XD393.3v
82XD393.3v's Avatar
thats bloody good power for a 302 with minamal work done to it u sure its not a 51
Old 23-08-2006, 12:23 PM   #14
XC 302
V8 Power
XC 302's Avatar
Thats almost exactly the same power my little 302 made with stock heads (auto). I would be dissapointed if yours didn't run a 14.
At 1800kg, i managed to just get a 15.2, no way is an xa coupe going to weigh that much.
1977 XC GXL 351 - 272rwkw - 12.6 @109mph
2008 FG XR8 Ute - 268rwkw
1994 EF Ghia I6 - 165rwkw
XC 302 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 11:52 AM   #15
benXaGt
Im positive its not a 351 we checked the compression and its definatly a 302.
How much does a coupe weigh?
hopefully i can get into the high 14's now. The Drags open in two weeks time i think (11 days).
Old 25-08-2006, 03:18 PM   #16
brenx
brenx's Avatar
if it's LSD you might. Single spinner? You'll be stuck in the 15's.
