Old 20-07-2006, 08:50 PM   #1
nitroman
nitroman
nitroman's Avatar
Default Which computer?
Hello again people. It's become apparent after I've fitted the cam to my AU1 xr8 that I need to re-calibrate the ecu. It's behaving better than after I installed it but it still has a hiccup now and then like it wants more fuel.
So, what do I do? I would like to re-map the fuel and ignition curve, but what tuner /ecu do I get. Some like the motec seem too complex for my needs.
Would I be better off getting a snapon scanner that can re-map fuel curves and I can use on other cars as well?
What is the go?! :
nitroman is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2006, 09:11 PM   #2
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Do a search on this... has come up too many times...
Your best bet is use the factory computer, but get an edit (re-flashing the current ECU with a heavily tweaked/tuned fuel map). This can be done at variou places... G&D would be first recommended or CAPA if they are in sydney... closer to Young....
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2006, 09:14 PM   #3
xr8ute
Back on the road
xr8ute's Avatar
CAPA Flash Tuner
Old 20-07-2006, 11:13 PM   #4
JC
JC's Avatar
Yep, Flash Tuner, tuned by Chris from Bluepower would be the way to go.
Ford Performance Club ACT
Old 21-07-2006, 12:16 AM   #5
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
Yep Flash tuner with a custom edit.I had a simular problem when my cam got installed.After a little playing with the tuner all was sweet.
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2006, 09:13 AM   #6
8pAc
RDP #181
8pAc's Avatar
If your in brisbane i highly recommend you give Steve at Redcliffe Dyno a call. I just had one of there systems installed to sort out the fuel and timing issues that popped up since changing heads. To sum up: B4 heads 228 rwhp, After heads 237 rwhp, After RDP ECU 253.9 rwhp. Sorted out light and WOT mixtures and timing and the car feels 100% happier through a hard run, not bogged down. Not sure if the system can do this but the lock up in the auto comes in at a better time, firmer maybe? Maybe the just tinkered a bit... ;)
Originally Posted by MRJUCY
Camrys like most Toyotas have always been ugly, poorly equiped & brain crushingly dull but that's what a lot of people look for in a car unfortunately. I like my fridge, it keeps my beer cold other people like them so much they want to drive them it seems.
8pAc is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2006, 11:09 AM   #7
Mechan1k
Mechan1k's Avatar
AFAIK Spiro at Autotech in Granville/Sydney does the CAPA Flash Tuner.
It just depends which is the closer place to you to get this done.
Old 21-07-2006, 11:20 AM   #8
MRJUCY
Fordless
MRJUCY's Avatar
Their is a bit of info on the flash tuner & a list of shops that can sort you out with one at the bottome of this page http://www.capa.com.au/ford_flash_tuner.htm
PS 8pac love the quote hadn't noticed it until now thanks
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2006, 06:12 PM   #9
nitroman
nitroman
nitroman's Avatar
Sounds like a custom edited flash tuner is the way to go , but is this different to the $995 capa tuner that I could do myself. A dyno flash tune might be better. How much does a dyno flash tune usually cost?
Old 21-07-2006, 06:14 PM   #10
JC
JC's Avatar
Flash Tuner/Capa flash is the same thing. Dyno tuning is around $500 to $600
Old 21-07-2006, 07:34 PM   #11
nitroman
nitroman
nitroman's Avatar
Is the CAPA flash tuner adjustable? Does it hook up with the pc so I can muck about with it or is it a pre-set thing that you load into your car's pcm and that's it?
Old 21-07-2006, 08:10 PM   #12
xr8ute
Back on the road
xr8ute's Avatar
It can if you buy the dealer software...
Old 21-07-2006, 08:43 PM   #13
nitroman
nitroman
nitroman's Avatar
So a custom flash tune is the go. Thanks for all your input, I'll let you all know what happens....
Old 21-07-2006, 08:51 PM   #14
JC
JC's Avatar
Yep - you actually get the option of 3 tunes (plus factory tune) in one box. For example, Valet tune, where rev limit is set at 3000rpm in all gears. Then you have a street tune, and a missus tune. Plus you get the standard Ford tune as well. You swap them over by uploading from the box.
Old 21-07-2006, 09:33 PM   #15
xr8ute
Back on the road
xr8ute's Avatar
Spot on ;)
