Old 16-07-2006, 03:44 PM   #1
zoomzoom
Default AU2 Fan are runing even when the engine is cold
Hi every one
I have an AU2 that when i start the engine when it is coild i find the thermo fans are running .
Is this normal
if not any ideas
Thanks
zoomzoom is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2006, 04:37 PM   #2
bodes-sh
you havent got the air con switched on have you? if it is then the thermo fans will run regardless of engine temp
Old 16-07-2006, 04:44 PM   #3
LUXO_8
windsor user
thats what i was thinking...... it does this to draw the heat out of the condensor
Old 16-07-2006, 10:24 PM   #4
zoomzoom
ok i will look at that to see if the a.c is on
Thanks
