Old 25-06-2006, 11:51 AM   #1
Zedjay
Zedjay's Avatar
Default fireing order the same EFvEB
gday dose anyone knoe if the fireing order the same between EB to EF??
im working on an EB that has CFI but has an EF engine in it.
i cant get it to start and i think its a spark prob,
it has spark at the plugs, it has fuel to the injectors but wont start
what do you guys say
cheers Rod
Zedjay is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 01:04 PM   #2
ratter
ratter's Avatar
Firing order should be the same 153624, do you have injector pulse?
Pit Lane Performance
Old 25-06-2006, 01:05 PM   #3
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Yep, firing order is the same EA-BF, and probably XK-BF
1-5-3-6-2-4
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 04:00 PM   #4
EF_Frmnt
EF_Frmnt's Avatar
99 percent of straight sixes will fire in this order.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 06:16 PM   #5
mintea
Donut King
fould plugs maybe, try different plugs
mintea is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 06:37 PM   #6
Walkinshaw
Two > One
Walkinshaw's Avatar
Sounds like the dizzy is 180deg out
Old 26-06-2006, 10:44 AM   #7
Zedjay
Zedjay's Avatar
i worked it out
the little gear thingy on the bottom of the dizzy shaft is missing some teeth
so every time i fixed the timing it would try to start then the rotor button would stop spinning
Old 26-06-2006, 08:08 PM   #8
ratter
ratter's Avatar
Before you just replace the dissy gear, make sure the oil pump is not seized, I got caught out recently, the oil pump had debri in it from a broken timing chain guide
