Old 25-06-2006, 08:20 AM   #1
Stav
Smile
Stav's Avatar
Default Pod vs panel filter for the quickest six?
So what flows better out of the two filters? What do the top 3 au six fords run. I believe Hamo ran a flat panel from memory and also tripower.This seems to go against the pro pod fans.
I have been of the belief that the panel does flow more than a pod.Can someone who runs a terrific time please mention what they are using ? Or any intake mods which really made a difference on a dyno or 1/4 mile. "It feels better" cannot account for measureable differences.
Old 25-06-2006, 10:52 AM   #2
JC
JC's Avatar
Spiro - it depends a lot on the size of the Pod. The ones that are as long as the are round are a restriction at higher flow needs (high rpm), but are OK for tootling around town. If you get a 3" neck pod and it's about a foot long, it will match or better a K&N or BMC Flat Panel for flow. This is what G&D use in their system.
Something like this:
Ford Performance Club ACT
Old 25-06-2006, 11:18 AM   #3
jonbays
TL40 Wagon?
Look its all good to try and get the best performing air intake system but keeping the air clean has to cost a bit of pwer and i really dont believe there is a measurable difference on the qtr whatever intake you use. Hasn't stopped me trying and there was more difference between runs than there was with or without snorkle or airbox or any intake at all.
Old 25-06-2006, 01:18 PM   #4
xr8ute
Back on the road
xr8ute's Avatar
I ran a 14.17 at 98.xx with a paper airfilter in my PBWAI.
How much air do you really need?
Old 25-06-2006, 01:49 PM   #5
Sleeperau
Highway Taxi
Default Pod Vs Panel
I remember reading a thread about a year ago or longer, : before aufalcon.com became part of the ford forums. In that thread your own tests witha g-tech revealed the pod was better than the panel filter in your car. What gives Stav?
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 02:49 PM   #6
FTE217
T3/Sprint8
FTE217's Avatar
Stav you are talking about 2/5ths of F all.....are you racing for $$ now ?
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 05:23 PM   #7
Stav
Smile
Stav's Avatar
The pod filter did get me slightly quicker in my tests yes .However looking at my pod filter in my standard airbox I am thinking that its too cramped for that little box.I think it may be restricted. Maybe I should build a bigger custom box? I am gonna write some plans on paper and get to bunnings for some sheet aluminium to build a new box.
Bluedriver 2/5 of f all is what I am chasing soon after wsid when the car is run as is. If it doesnt do better than a 15.19 then yes it is very important to me.A few of those is what adds up to cheap power improvement.
Old 25-06-2006, 06:06 PM   #8
xr8ute
Back on the road
xr8ute's Avatar
I agree with you there Stav. There seems like hardly any room around the pods designed to work in the stock airbox (that was designed for a panel).
Assuming they are made of the same material, the first comparison between pod and panel, would be to compare the surface area of the filter.
Old 25-06-2006, 06:25 PM   #9
Stav
Smile
Stav's Avatar
I am using my vaccuum cleaner theory and applying this to cars.Since doing this understanding my cars engine has been much clearer. I am thinking that there must be a greater pressure drop of air trying to get sucked into a pod filter from 360 degrees where a flat panel filter would allow the air a much more direct path to enter the intake tube and more cfm
Old 25-06-2006, 08:48 PM   #10
AU-MUSTD
Flat floor shifter
AU-MUSTD's Avatar
The airbox for my pod is the size of my front bumper. It only cost 30 dollars from super cheap for the intake tubing and a 90mm hole straight through the bottom where the airbox used to be.. How much bigger do you need.
AU-MUSTD is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2006, 09:11 PM   #11
buickman
buickman
buickman's Avatar
The only thing I found was the induction noise was noticable & it appeared to pick up down below if you floored it better. Never got around to test it on the dyno to see if it produced better power to the wheels over a panel filter. I suppose I should have removed the air intake system when I sold the car so some one else could try it to see if there is any gain on a dyno over the panel filter on their car
Old 25-06-2006, 10:45 PM   #12
Stav
Smile
Stav's Avatar
Any pics?
Old 26-06-2006, 12:10 PM   #13
ClassicAU
this thread has come at good timing, as i was going to start a similar one myself, but i guess i could just ask the question here. i am looking to get a new filter, as mine is just the stock paper one. i have a standard motor, and the only change i have made so far is the tickford snorkle. would a pod do anything at all for me, or should i just stick with a panel? i was looking at K&N vs BMC, which do most people use?
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2006, 12:18 PM   #14
blackers10
blackers10's Avatar
i purchased the tickford snorkel and a K&N panel filter
and noticed my car seemed smoother and a deeper note from the engine bay rather than a home vacume sound so to speak when under full throttle
then i cut a rectangle about the size of a business card out of the front of my airbox and i dont think it made much difference at all except it is a lil noiseyer induction just a little bit tho
and classicau
i think it depends how far you wish to go later
ie if you plan on going NUTS with the car get the G&D kit sooner rather than later
as there is no point in spending $100 odd on a filter then wanting to change it 6 months down the track to a pod or panel when the initial cost hasnt repayed for it self if that makes sense
good luck in your choice i think it is a much of a muchness but would like the G&D intake as it is fully tested
Old 26-06-2006, 01:03 PM   #15
ClassicAU
i dont think i will ever go any further than extractors and an exhaust with this car, and that most likely will not be for a while yet. what does the G&D kit consist of? is that a new air box as well? i doubt it would be of much use to me if my car is going to stay standard for a while though will it?
Old 26-06-2006, 02:21 PM   #16
xr8ute
Back on the road
xr8ute's Avatar
Yeah, G&D kit is a full custom airbox w/pod.
Unless you plan on going for a custom airbox, I recommend sticking with a panel filter. Paper works well, just dont forget to change it at each oil change ;)
Old 26-06-2006, 02:40 PM   #17
Mechan1k
Mechan1k's Avatar
Do G&D make ones with springs for LPG ... don't exactly want to blow apart a very expensive airbox.
Old 26-06-2006, 04:11 PM   #18
JC
JC's Avatar
It's not actually an airbox, but a Pod filter with a great big cover that looks like a box. The cover is totally open at the front though. So if you have a balance pipe, the G&D setup is probably no good.
Old 26-06-2006, 04:54 PM   #19
Mechan1k
Mechan1k's Avatar
Ahhhh ... may as well just stick with the standard setup with Redline panel filter in it ... it does the job
I'll just change the pipe between the throttle body and the airbox.
Old 26-06-2006, 07:45 PM   #20
Stav
Smile
Stav's Avatar
Well I am sticking to my pod after all that. It seems to me that for some strange reason the car pulls harder down low with the pod.Much harder.
Old 26-06-2006, 08:25 PM   #21
buickman
buickman
buickman's Avatar
I did notice it pulled harder down low with the pod filter but did not get any proof if it gained any better rwkw
Old 26-06-2006, 09:32 PM   #22
AU-MUSTD
Flat floor shifter
AU-MUSTD's Avatar
Any pics?
I've been meaning to do one on my car in the workshop builds so maybe by the weekend i'll have full pics of the new wheels, ride hieght , gas set up, custom intake behind bumper etc.
Old 26-06-2006, 10:18 PM   #23
Stav
Smile
Stav's Avatar
A pod certainly gives more torque down low.The panel filter felt very strong up top but the pod seemed to link low to high power.
