Old 19-06-2006, 07:47 PM   #1
alpineau
alpineau's Avatar
Default Fuel Pump Problems
Hi Guys
I think my fuel pump may be packing it in, When the car is running i hear a hum comming from the rear left hand side of the car. Sounds similar to when you turn the ignition on and you hear the pump start except the hum stays there
Any ideas, the car seems to be running fine no loss of power or stalling. If it is the fuel pump is it hard to replace it.
Alpine
OLD - 2000 AUII FUTURA 75TH ANNIVERSARY GOLD 4 SPEED AUTO
OLD - 2006 BF MK2 XR6 BIONIC 4 SPEED AUTO[
OLD - 2007 BF MK2 XR6T SILHOUETTE 6 SPEED MANUAL
CURRENT - 2009 FG G6E BLUE 6 SPEED AUTO
alpineau is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 07:50 PM   #2
Au2falcons
Winter all year round
Hmmm....mine hums when it's running also, however I only hear it whilst the car is cold, once it's warmed up you can bearly hear it.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 09:20 PM   #3
alpineau
alpineau's Avatar
The Car is still under warranty so i might just take it to them ans let them see what they can find, If is it is the pump then it should be under warranty.
Old 20-06-2006, 07:11 AM   #4
james22
With da Warlords
james22's Avatar
I got a series II about 9months ago, and that was my first question as well. It seemed noisy but mechanic said it should be fine. Excess noise caused by vibration the fuel pump is making when running. Keep us posted anyway, wouldnt mind a second opinion on that. :-)
Old 20-06-2006, 09:54 AM   #5
Tri Power 289
Back in the Game!
Tri Power 289's Avatar
Alpine
Unless it absolutely has to be done,I wouldn't tackle changing it yourself unless you've got access to the proper tools. It can be done without them but its not fun. The tin cover is glued to the boot floor with a rubber sealant and is almost impossible to remove without bending it.
The lines have a connector that really should be removed with a special tool and the large plastic lock ring holdig the whole assembly in, also needs a special tool to undo.
You can do it with a hammer and screwdriver or similar, but the chances of damaging it (being plastic) are high and it's damn hard work.
Also, buy the pump from Bursons or somewhere similar as the genuine pumps are made in the same factory but are more than twice the price.
Hope that helps.
2016 Focus RS MK3
XHII XR8 Falcon Ute S/C 5.0 Manual
'66 Mustang coupe 289 Auto
70 Mustang Mach1 351 4V/Shaker Auto
Previous forum rides:
XH Falcon Ute 4.0 Auto
BF XR8 5.4 Manual
'88 60 Series Landcruiser Turbo Diesel.
Komatsu 830E Haul Pac- 2500hp, 165tonnes.
AUIII XR6 HP: Prepared by Aussie Car Enhancements & Custom Tuned by Blue Power to a record setting 14.22@96mph.
BA Fairmont Ghia 5.4 3V :Unfinished business.
Tri Power 289 is offline   Reply With Quote Multi-Quote with this Post
