Old 16-06-2006, 02:24 PM   #1
teabags2
Bob
Default Anyone done an AU VCT Conversion?
Does anyone know how hard/expensive it is to fit VCT to an AU3 4lt?
I notice from the Gregories manual that the computer has an output for it and the gear drive replaces the existing sprocket. The solenoid protrudes out of the rocker cover and it has an oil connection to the oil pump.
What needs to be replaced? assume sprocket and perhaps rocker cover. What about connecting to the oil pump? Is the cam and head the same or would they need to be changed out too?
Anyone have any knowlege of this and is it realy of benefit?
teabags2 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 02:30 PM   #2
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
From what I know, you will need a VCT belt and VCT pulley, VCT head with cam, etc, and a VCT computer. Even if the wiring is there with the current computer, it will need an edit flash...
You may also need a VCT cam chain - not too sure.
I looked into it, and your best getting a VCT motor from a wreck.... would be cheaper and easier, and you don't actually have a moddified engine... it's just a swap...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 03:53 PM   #3
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
Deffiniteley cheaper and easier just to get the whould engine swapped - I just did it and it cost me $1200 int=stalled and I sold the old engine for $500, and the old computer for $150, so it only ended up costing me $550 all up to do.
I dont think a standard ecu can run the vct component even if you get it edited. but as stated above, even if it can and you dont need the computer, you'll still need the bits and pieces mentioned above which will probably cost you more to buy individualy once itsall done and all the messin around involved.
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 06:39 PM   #4
bodes-sh
^^^so the money you found under your back seat nearly paid for it lol...i guess sometimes it does pay to get a used car
Old 16-06-2006, 07:42 PM   #5
robbo_yobbo
Kick out tha Jams
hahaha, yea, i guess it does, never thought of it that way
