Fantastic Plastic
Hi guys , Since i bought my car i have has a small white moth stuck behind the clear plastic on the dash/cluster just next to the DTE display.
Before i go trying to pull things apart and probably wreck something , i thougt i would ask first how to remove the plastic cover , as im sure someone here has done it before . Any advice appreciated , cheers ;) .
Fantastic Plastic
is it just those 2 small lugs you remove , at the top of the dash/cluster on the outer side of the clear plastic ?
Here you go
http://www.aufalcon.com/Tech/techinstrument.htm They are fairly easy to break/snap... Good thing is that you can buy the parts from Ford, cheap. The plastic screen is only $20.
AUIII Falcon Forte, with SIX Appeal |
#4 | |||
Fantastic Plastic
Fantastic Plastic
WOW ! , that was too easy , i was expecting a bit more drama than that, thanks again.
speaking of which, yesterday night, my DTE area went all dim.... but the odo is still bright? what gives there? is it a led problem? as the DTE is still visible just not as bright as the other 1/2 hmmmm damm it annoys me....
#7 | |||
Fantastic Plastic
#8 | |||
![]() Join Date: Jan 2005
cheers
Bugger! so can I just do what has been suggested in here and remove the cluster and replace it.. which I assume is screws and then whatever... saw a write up on it by someone ine here, in fact I think it was JC! |
