Old 25-05-2006, 06:35 PM   #1
LTD351T
LTD351T's Avatar
Default bit of help about rim/tyre sizes?
I am curious about what the rules are on rim sizes, IE if I run 16" rims on front do I have to run 16" rims on back too?
I have an XE LTD and the front brakes are too big for 15" I have to run a 16" on the front.
My choice was 15x8 rear rim with 28x10.5 MT slick, and matching front runners but on 16x5 rims??
LTD351T is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2006, 09:31 PM   #2
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Cant find anything that mentions that in the ANDRA rule book,all it says is if you use crossply's on the rear you have crossply's on the front,so I'm thinking it would be ok.
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2006, 09:31 PM   #3
crispy79
crispy79's Avatar
should be fine a t/d runs a 16" rear and a 15" front just make sure front runners are speed rated, and if using slicks on rear then use a cross ply on front as they tend 2 wander about with slicks and using radial fronts make steering to direct
mk2 cortina, 2v clevo power, in build (still)
This argument that you are carrying on with is akin to shuffling deckcahirs on the Titanic.
crispy79 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2006, 07:46 AM   #4
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
On the street its illegal to run different size rims and to run at a street meet you have to comply to those rule ( well most of them) so they might pick it up when you go through scrutineering. I know when I have my F/runners & slicks on they always check my tyres and rims.
Give it a go and see what happens, never have asked them how indepth they check your rims.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2006, 01:36 PM   #5
nugget378
Weezland
nugget378's Avatar
I scrutineer first then put the slicks on, just to make sure they dont look too hard at the tailshaft loop. Quite a few guys I know do this and run on radial fronts.
Old 26-05-2006, 05:30 PM   #6
brenx
brenx's Avatar
I run 15" rims with front runners and 16" rims with slicks on them. I'll be doing that till I kill the slicks. Then I'll get some 15" rims widened and go from there. Doing the reverse won't be an issue.
I've ran at Calder Park and Heathcote in this very trim many times.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2006, 09:10 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
I run std 17's front and 15 X7 rear with radial slicks....
You cannot run X ply slicks with radial fronts.....
Daily driver GTE FG..
Old 27-05-2006, 04:53 PM   #8
LTD351T
LTD351T's Avatar
Thanks for the the help, sounds like I can get away with it.
