Old 23-05-2006, 07:59 PM   #1
calv1234
Default Mitsubishi Prob ?
hey all I couldnt find any decent mitsubishi forums around so thought i would ask here.. The window in mitsubishi triton is getting jammed about half way, so im trying to take the door trim off but cant figure out how to take off the window winder? anyone have any ideas?
Thanks
calv1234 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2006, 08:04 PM   #2
Jet-Star
Get the flat special tool, and pop the little clip out from behind it.
Jet-Star is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2006, 08:21 PM   #3
Windsor220
Now Fordless
Windsor220's Avatar
If you didnt already know, Tritons have a revised window runner because the original rubber is too thick and makes the window tight to operate. Gets replaced on warranty.
To get the window winder off you have to get the clip off from behind the winder as previously said. You can use a small flat blade screw driver.
