Old 13-04-2006, 07:39 PM   #1
neyzen
Arrow Public Car Emissions tester Survey
As your car ages, it runs less efficiently. Running your car inefficiently means that you end up spending more on petrol, and you pollute the environment more. Imagine if you could test your motor vehicle emissions by your self, at your local petrol station, for a small fee.
We are developing a motor vehicle emissions tester that is to be placed at petrol stations. The emissions tester is designed to be easy to use, so that any one will be capable of using it by them selves. The emissions test will take approximately 10 minutes to complete.
Please click here to complete the survey. Only 4 questions!
Thanks,
Murray
neyzen is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 07:47 PM   #2
coyote
Paint Repairs Spoilers
coyote's Avatar
Interesting concept
Is this type of info generally available when you get you car dyno tested "??
Tyre smoke - nah must be smoke from the running in oil / Sorry officer, just put some tyre shine, did not think it would do that.
Unfit - How could I be, always running off at the mouth and jumping to conclusions
coyote is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 08:19 PM   #3
John03
Coyote, it depends what type of dyno test. The more sophisticated emissions testing procedures do use a dyno to simulate a 'normal driving cycle', and measure your car emissions over that drive cycle.
I've never had a dyno test done, so I'm not sure what they'd be testing for exactly. But if the purpose of the dyno test is to enhance performance, rather than to just find out the kW rating of your car, then chances are they would be testing emissions to find out how well the engine is running.
Based on the exhaust emissions they can tell whether the car is running too rich or lean, or if there's other problems with the engine.
John03 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 09:16 PM   #4
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Not a bad idear. Like a heath check up for your car.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 09:31 PM   #5
TEaaron
TEaaron's Avatar
I didn't even have to change any of the origanal options.
TEaaron is offline   Reply With Quote Multi-Quote with this Post
