Old 31-03-2006, 07:36 PM   #1
HLC
Audi S3
Default feeding wires from engine bay to the inside of the car...
hey guys...
i was having a look under my bonnet today trying to figure out where to feed a wire from the engine bay to the inside of the car, for like an amp or something... and i cant find where.
i found the wiring going somewhere near the steering column but i coudnt feed anything anyway...
is anybody able to tell me where i can feed wires for this sort of stuff?
cheers, HLC.
Old 31-03-2006, 07:45 PM   #2
SIKSIX
Its gone V
SIKSIX's Avatar
i hate taking off and putting gromets back on so i just drilled it next to my clutch cable and cable tied to it, then to the battery leads, nice and neat.....for me anyways.
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 07:46 PM   #3
KOUPE76
OLD SKOOL BABY
KOUPE76's Avatar
Originally Posted by HLC
hey guys...
Grab a wire coat hanger, straighten it then round the tip with some pliers and push it through the hole. :
Mick
Old 31-03-2006, 08:04 PM   #4
S3SR
S3SR's Avatar
yeah use the coat hanger than u can tie string or whatever to it and pull it back through then tie it to your new wire then pull it back through - did this when installing my bonnet release cable
the hole is the one up from the radiator resevour and a thick black cable running into it(bonnet release cable) just so u no what im talking about
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 08:25 PM   #5
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
It's a little difficult but keep persisting and it eventually goes through, mine was tight as... reminds me of a girl i once knew...
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 09:01 PM   #6
Baboon_AU
Baboon_AU's Avatar
on autos there is a grommet/plug for where the cluth cable is meant to be. just take it out and put it through there and then force the plug back in.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 07:42 PM   #7
HLC
Audi S3
ok i found what felt like this rubber thing that the wires are going through... i got an auto so ive no idea where the clutch cable is sposed to be...
but i tried putting a coathanger through the rubber thing. but to no avail :S can anyone tell me where this rubber thing leads/comes out in the engine bay so i can go the other way?
Old 01-04-2006, 08:16 PM   #8
Whoosha
AU DIE HARD
Whoosha's Avatar
looking from the front of your car the brake boosters on your left go about a hand width across + down mid way between the eng. + booster there should be a grommet on fire wall pull it out that is ware the clutch cable would have been you should get your wires thru there it can then be seald up again with silastic or caulking compound..hope this helps
Cheers ..Whoosha
Originally Posted by Riksta
Old 02-04-2006, 09:37 AM   #9
HLC
Audi S3
alright, thanks, ill have a looksie.
